attaching an interrupt in beaglebone bsp
Angelo Fraietta
newsgroups at smartcontroller.com.au
Wed Jun 17 22:00:49 UTC 2015
It was not, so I installed it, did a make clean and had same error
On Wed, Jun 17, 2015 at 5:36 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/06/2015 5:24 pm, Angelo Fraietta wrote:
> > Fails here during build
> > make[6]: Leaving directory
> `/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/syscall01'
> > Making all in dl01
> > make[6]: Entering directory
> `/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/dl01'
> > arm-rtems4.11-gcc -B../../../../../beagleboneblack/lib/ -specs bsp_specs
> > -qrtems -DHAVE_CONFIG_H -I.
> > -I../../../../../../../rtems-src/c/src/../../testsuites/libtests/dl01
> > -I..
> -I../../../../../../../rtems-src/c/src/../../testsuites/libtests/../support/include
> > -mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
> > -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
> > dl-o1.o -MD -MP -MF .deps/dl-o1.Tpo -c -o dl-o1.o
> ../../../../../../../rtems-src/c/src/../../testsuites/libtests/dl01/dl-o1.c
> > mv -f .deps/dl-o1.Tpo .deps/dl-o1.Po
> > w -f dl.tar dl-o1.o
> > 22:50:56 up 10 days, 16:36, 1 user, load average: 0.91, 0.56, 0.27
> > USER TTY LOGIN@ IDLE JCPU PCPU WHAT
> > ../../../../../../tools/build/rtems-bin2c -C dl.tar dl-tar.c
> > cannot open dl.tar for reading
> > make[6]: *** [dl-tar.c] Error 1
> Do you have pax installed on your system ?
> Ideally configure should check for this.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20150618/9b7f0377/attachment-0001.html>
