libbsdport and newer Intel NICs
    Wu, Mark H.
    Mark.H.Wu at disney.com
    Wed Jun 17 23:17:26 UTC 2015
I've gotten around the executive shutdowns that I was having while trying to bring up the network interfaces on my board, and have a few questions.
1. The mechanism for network interfaces in RTEMS itself was a little more clean - you provided a list of devices and it looped through the list with an attachment function. It seems like with libbsdport, this is more awkward - you create an attachment function that calls libbsdport_netdriver_attach() with a pointer to the entry in the table of rtems_bsdnet_ifconfig structures. My problem was that I had skipped that step and had tried to use libbsdport_netdriver_attach() as the attachment function, with poor results. But now you basically have to have a hand-coded unique function for each network device? (A unique function for each entry?) It seems odd that I create rtems_bsdnet_config with a list of rtems_bsdnet_ifconfig structures, each of which has a pointer to an attach function, where I have to create attach functions that point back to that entry which points to it. Or am I missing something? But since there's no parameter telling the attach function about that entry, I have to create unique attach functions for each entry so that they can point to the correct element in the tables?
2. I believe that my Ethernet interfaces are probably newer than the devices in libbsdport. I am currently running on a hand-me-down x86 board with the following devices: LAN1: Intel 82567, LAN2: Intel 82583V. I am not familiar with libbsdport or its origins... where should I go to look to see if there is a newer version that supports these chips? Or is this the wrong question or wrong approach?
