attaching an interrupt in beaglebone bsp
Thu Jun 18 03:47:35 UTC 2015
On 18/06/2015 8:00 am, Angelo Fraietta wrote:
> It was not, so I installed it, did a make clean and had same error
Great. Looking at the error below ...
> On Wed, Jun 17, 2015 at 5:36 PM, Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
>     On 17/06/2015 5:24 pm, Angelo Fraietta wrote:
>     > Fails here during build
>     > make[6]: Leaving directory
>     > `/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/syscall01'
>     > Making all in dl01
>     > make[6]: Entering directory
>     > `/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/dl01'
>     > arm-rtems4.11-gcc -B../../../../../beagleboneblack/lib/ -specs bsp_specs
>     > -qrtems -DHAVE_CONFIG_H -I.
>     > -I../../../../../../../rtems-src/c/src/../../testsuites/libtests/dl01
>     > -I..
>     >  -I../../../../../../../rtems-src/c/src/../../testsuites/libtests/../support/include
>     >   -mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
>     > -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
>     > dl-o1.o -MD -MP -MF .deps/dl-o1.Tpo -c -o dl-o1.o
>     > ../../../../../../../rtems-src/c/src/../../testsuites/libtests/dl01/dl-o1.c
>     > mv -f .deps/dl-o1.Tpo .deps/dl-o1.Po
>     > w -f dl.tar dl-o1.o
For some reason $(PAX) is not set. See line 21 of ...
https://git.rtems.org/rtems/tree/testsuites/libtests/dl01/Makefile.am#n21
I suggest you delete the current build directory and run configure
again. The value for PAX may have been cached.
