libbsdport and newer Intel NICs
Thu Jun 18 04:15:25 UTC 2015
On 18/06/2015 9:17 am, Wu, Mark H. wrote:
> I've gotten around the executive shutdowns that I was having while trying to bring up the network interfaces on my board, and have a few questions.
Great.
> 1. The mechanism for network interfaces in RTEMS itself was a little more clean - you provided a list of devices and it looped through the list with an attachment function. It seems like with libbsdport, this is more awkward - you create an attachment function that calls libbsdport_netdriver_attach() with a pointer to the entry in the table of rtems_bsdnet_ifconfig structures. My problem was that I had skipped that step and had tried to use libbsdport_netdriver_attach() as the attachment function, with poor results. But now you basically have to have a hand-coded unique function for each network device? (A unique function for each entry?) It seems odd that I create rtems_bsdnet_config with a list of rtems_bsdnet_ifconfig structures, each of which has a pointer to an attach function, where I have to create attach functions that point back to that entry which points to it. Or am I missing something? But since there's no parameter telling the attach function about that entry,!
  I have to
>  create unique attach functions for each entry so that they can point to the correct element in the tables?
I do not think you are missing anything. It has been many years since I
played with this code and I seem to remember a number of steps are
needed to get it working. The code I last used is here if it helps ....
https://git.rtems.org/chrisj/rtl.git/tree/init.c
> 2. I believe that my Ethernet interfaces are probably newer than the devices in libbsdport. I am currently running on a hand-me-down x86 board with the following devices: LAN1: Intel 82567, LAN2: Intel 82583V. I am not familiar with libbsdport or its origins... where should I go to look to see if there is a newer version that supports these chips? Or is this the wrong question or wrong approach?
Libbsdport is present and ok as is for use with the existing stack. The
work to add a driver is more than most because the BSD base is limited.
The rtems-libbsd path is a better. It is being worked on and improving
and it is where efforts are being focused but it is new.
