Why doesn't rtems_blkdev_sg_buffer have next pointer?
Chan Kim
ckim at etri.re.kr
Thu Jun 18 12:16:44 UTC 2015
Hi all,
I have a basic question.
in rtems 4.10.99 version, I see in cpukit/libblock/include/rtems/blkdev.h,
typedef struct rtems_blkdev_sg_buffer {
rtems_blkdev_bnum block; // this seems to be the start block number of this access
uint32_t length;
void *buffer;
void *user;
} rtems_blkdev_sg_buffer;
typedef struct rtems_blkdev_request {
rtems_blkdev_request_op req;
rtems_blkdev_request_cb done;
void *done_arg;
rtems_status_code status;
uint32_t bufnum; // this seems to be # of blocks
rtems_id io_task;
rtems_blkdev_sg_buffer bufs[0];
} rtems_blkdev_request;
the rtems_blkdev_request has only a single entry of rtems_blkdev_sg_buffer. But usually scatter-list uses next pointer to link buffers in host memory together. But in rtems, why isn't there such link field? Does the block device request I/O with only a single buffer always?
Could somebody please answer to this question?
regards,
Chan Kim
