Why doesn't rtems_blkdev_sg_buffer have next pointer?
Thu Jun 18 13:17:33 UTC 2015
For an SD/MMC driver you should operate at this level since this is
covered by "freebsd/sys/dev/mmc/mmcsd.c".
On 18/06/15 14:16, Chan Kim wrote:
> Hi all,
> I have a basic question.
> in rtems 4.10.99 version, I see in cpukit/libblock/include/rtems/blkdev.h,
> typedef struct rtems_blkdev_sg_buffer {
> rtems_blkdev_bnum block;             // this seems to be the start block number of this access
> uint32_t length;
> void *buffer;
> void *user;
> } rtems_blkdev_sg_buffer;
> typedef struct rtems_blkdev_request {
>    rtems_blkdev_request_op req;
>    rtems_blkdev_request_cb done;
>    void *done_arg;
>    rtems_status_code status;
>    uint32_t bufnum;                       // this seems to be # of blocks
>    rtems_id io_task;
>    rtems_blkdev_sg_buffer        bufs[0];
> } rtems_blkdev_request;
> the rtems_blkdev_request has only a single entry of rtems_blkdev_sg_buffer. But usually scatter-list uses next pointer to link buffers in host memory together. But in rtems, why isn't there such link field? Does the block device request I/O with only a single buffer always?
> Could somebody please answer to this question?
> regards,
> Chan Kim
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
