attaching an interrupt in beaglebone bsp
Fri Jun 19 02:41:24 UTC 2015
On 18/06/2015 4:03 pm, Angelo Fraietta wrote:
> That worked. I have the test suites built successfully. I just need to
> dd to a disk and see if it works.
Excellent.
> So I think we need to add the other dependency checks in sb-check to
> test for the dependencies that did not show up as missing.
Would you like to create patch ? It means adding pax to
source-builder/defaults.mc.
Thanks
