RTEMS on Intel Core 2 Duo
Fri Jun 19 20:44:15 UTC 2015
On Fri, Jun 19, 2015 at 4:37 PM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> On June 19, 2015 3:33:50 PM CDT, Wendell Silva <silvawp at gmail.com> wrote:
>>Hello,
>>What is the option (or the switch of the configure script or, even
>>better, the rtems source builder option) to compile RTEMS for Intel
>>Core 2 Duo?
>>Is pc686 bsp compatible with Intel Core 2 Duo?
> Any variant will run but the SSE one is likely the best match. This is also the minimum (and only) variant high enough architecturally to support SMP.
> Also there is a ticket for an update that needs to the SMP synchronization algorithm during a context switch.
https://devel.rtems.org/ticket/2183
>>Thanks,
>>--Wendell
> --joel
> users mailing list
> users at rtems.org
