attaching an interrupt in beaglebone bsp
Angelo Fraietta
newsgroups at smartcontroller.com.au
Sat Jun 20 03:08:15 UTC 2015
I did the get from Ben's beagle link. I don't have permissions to change
those.
On Fri, Jun 19, 2015 at 3:52 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 19/06/2015 1:54 pm, Angelo Fraietta wrote:
> > You will have to step me through what to do to make the patch and upload
> > it.
> Open up source-builder/defaults.mc and copy the __tar entry and add a
> __pax line (it is sorted). On MacOS and FreeBSD pax is in /bin/pax so
> please use this as the default.
> You then need to add pax as optional for Windows because pax is
> currently not in any MSYS2 packages. To do this you need to edit
> source-builder/sb/windows.py and adding it to the platform specific list
> as optional.
> Commit the change with a suitable commit message and email the devel
> list with the patch. There is git help on line for doing this that
> explains it better than I can.
> > There were other dependencies also that need to be added to it also.
> I do not mind adding pax but RTEMS should handle a missing pax better.
> The RSB check is not suppose to be mega check of any thing a package
> might need. It puts demands on to users for things they may never use.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20150620/bb87e11b/attachment.html>
