rtems-libbsd
Gene Smith gds at chartertn.net
Tue Jun 23 00:03:56 UTC 2015
On 06/22/2015 07:43 PM, Wu, Mark H. wrote:
> Now the problem I'm having is a bit more baffling:
> make: Circular freebsd/contrib/libpcap/scanner.c <- freebsd/contrib/libpcap/scanner.c dependency dropped.
> i386-rtems4.11-gcc --pipe -B/<installDir>/i386-rtems4.11/pc386/lib/ -specs bsp_specs -qrtems     -mtune=i386      -Wall  -O2 -g  -fno-strict-aliasing -ffreestanding -fno-common -Irtemsbsd/include -Irtemsbsd/i386/include -Ifreebsd/sys -Ifreebsd/sys/i386/include -Ifreebsd/sys/contrib/altq -Ifreebsd/sys/contrib/pf -Ifreebsd/include -Ifreebsd/lib/libc/include -Ifreebsd/lib/libc/isc/include -Ifreebsd/lib/libc/resolv -Ifreebsd/lib/libutil -Ifreebsd/lib/libkvm -Ifreebsd/lib/libmemstat -Ifreebsd/lib/libipsec -Irtemsbsd/sys -ImDNSResponder/mDNSCore -ImDNSResponder/mDNSShared -ImDNSResponder/mDNSPosix -Itestsuite/include -DHAVE_RTEMS_PCI_H=1 -Wall -Wno-format -MT freebsd/contrib/libpcap/scanner.o -MD -MP -MF freebsd/contrib/libpcap/scanner.d -std=gnu11 -D__FreeBSD__=1 -DBSD=1 -DINET6 -D_U_=__attribute__((unused)) -DHAVE_LIMITS_H=1 -DHAVE_INTTYPES=1 -DHAVE_STDINT=1 -DHAVE_STRERROR=1 -DHAVE_STRLCPY=1 -DHAVE_SNPRINTF=1 -DHAVE_VSNPRINTF=1 -DHAVE_SOCKADDR_SA_LEN=1 -DHAVE_NET_IF_MEDIA_H=1 -DHAVE_S
 Y
S
>   _IOCCOM_H=1 -DNEED_YYPARSE_WRAPPER=1 -Dyylval=pcap_lval -c freebsd/contrib/libpcap/scanner.c -o freebsd/contrib/libpcap/scanner.o
> /bin/sh: -c: line 0: syntax error near unexpected token `('
> /bin/sh: -c: line 0: `i386-rtems4.11-gcc --pipe -B/<installDir>/i386-rtems4.11/pc386/lib/ -specs bsp_specs -qrtems     -mtune=i386      -Wall  -O2 -g  -fno-strict-aliasing -ffreestanding -fno-common -Irtemsbsd/include -Irtemsbsd/i386/include -Ifreebsd/sys -Ifreebsd/sys/i386/include -Ifreebsd/sys/contrib/altq -Ifreebsd/sys/contrib/pf -Ifreebsd/include -Ifreebsd/lib/libc/include -Ifreebsd/lib/libc/isc/include -Ifreebsd/lib/libc/resolv -Ifreebsd/lib/libutil -Ifreebsd/lib/libkvm -Ifreebsd/lib/libmemstat -Ifreebsd/lib/libipsec -Irtemsbsd/sys -ImDNSResponder/mDNSCore -ImDNSResponder/mDNSShared -ImDNSResponder/mDNSPosix -Itestsuite/include -DHAVE_RTEMS_PCI_H=1 -Wall -Wno-format -MT freebsd/contrib/libpcap/scanner.o -MD -MP -MF freebsd/contrib/libpcap/scanner.d -std=gnu11 -D__FreeBSD__=1 -DBSD=1 -DINET6 -D_U_=__attribute__((unused)) -DHAVE_LIMITS_H=1 -DHAVE_INTTYPES=1 -DHAVE_STDINT=1 -DHAVE_STRERROR=1 -DHAVE_STRLCPY=1 -DHAVE_SNPRINTF=1 -DHAVE_VSNPRINTF=1 -DHAVE_SOCKADDR_SA_LEN=1 -DHAVE_NET
I
>   F_MEDIA_H=1 -DHAVE_SYS_IOCCOM_H=1 -DNEED_YYPARSE_WRAPPER=1 -Dyylval=pcap_lval -c freebsd/contrib/libpcap/scanner.c -o freebsd/contrib/libpcap/scanner.o'
> Makefile:114: recipe for target 'freebsd/contrib/libpcap/scanner.o' failed
> make: *** [freebsd/contrib/libpcap/scanner.o] Error 1
There are a bunch of problems with the Makefile since tcpdump was added
and I suggested some fixes but, since it is deprecated, it won't be
fixed. See this posting for the manual fixes you can make:
https://lists.rtems.org/pipermail/users/2015-June/029079.html
-gene
