rtems-libbsd
Tue Jun 23 06:31:38 UTC 2015
On 23/06/15 02:03, Gene Smith wrote:
>>   F_MEDIA_H=1 -DHAVE_SYS_IOCCOM_H=1 -DNEED_YYPARSE_WRAPPER=1
>> -Dyylval=pcap_lval -c freebsd/contrib/libpcap/scanner.c -o
>> freebsd/contrib/libpcap/scanner.o'
>> Makefile:114: recipe for target 'freebsd/contrib/libpcap/scanner.o'
>> failed
>> make: *** [freebsd/contrib/libpcap/scanner.o] Error 1
> There are a bunch of problems with the Makefile since tcpdump was
> added and I suggested some fixes but, since it is deprecated, it won't
> be fixed. See this posting for the manual fixes you can make:
> https://lists.rtems.org/pipermail/users/2015-June/029079.html
In case nobody wants to fix the Makefile, then we should remove it.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
