clock_gettime() result going backwards on LEON3?
Tue Jun 23 15:06:54 UTC 2015
On 6/23/2015 9:48 AM, Miller, Scott A. wrote:
> It was actually pulled before I joined the project, so I am a bit fuzzy on the details, but I believe October 2013.    It appears to be a download of the RCC from Gaisler.  Here's VERSION:
> samiller at buttercup:/project/RTEMS/rtems-4.10$ cat VERSION
> RCC-1.1.99.12a. RTEMS-4.10, GCC 4.3.3
There is a PR for that and I think it is fixed on the branch.
The simplest way to check is to clone the repo, check out the branch
and look at the history for leon3/clock/ckinit.c. I suspect the code
in bsp_clock_nanoseconds_since_last_tick() will look different from
what you have. It tracks back to this change:
     2011-03-04  Joel Sherrill <joel.sherrilL at OARcorp.com>
         PR 1748/bsps
         * clock/ckinit.c, include/leon.h: When the clock tick generates an
         interrupt WHILE we have interrupts disabled doing a get TOD or
         uptime, the get nanoseconds handler was returning a bogusly large
         number.
Assuming what you have is 4.10 plus some patches. It is likely missing this
one.
If that doesn't do it, then either I am guessing the wrong rtems version
or we have a different issue.
Recently 4.11 has had time rework and this code was touched again. So if
you are using the git master, the problem and solution will be different.
> Scott
> On Jun 23, 2015, at 9:39 AM, Joel Sherrill <Joel.Sherrill at OARcorp.com> wrote:
> On 6/23/2015 9:11 AM, Miller, Scott A. wrote:
>> Hello,
>> I'm observing that intermittently, that two successive calls to clock_gettime() will result in the 2nd timespec result being "before" the 1st timespec result.
>> Here's the code and some example output showing this:
>> <code snippet>
>> #include <rtems.h>
>> #include <bsp.h>
>> #define CONFIGURE_INIT
>> rtems_task Init(rtems_task_argument ignored);
>> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>> #define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER      1
>> #define CONFIGURE_INIT_TASK_ATTRIBUTES               RTEMS_FLOATING_POINT
>> #define CONFIGURE_INIT_TASK_STACK_SIZE               (10 * RTEMS_MINIMUM_STACK_SIZE)
>> #define CONFIGURE_MAXIMUM_TASKS                      13
>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>> #define CONFIGURE_MAXIMUM_DRIVERS                    16
>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS     32
>> #define CONFIGURE_EXTRA_TASK_STACKS                  (10 * RTEMS_MINIMUM_STACK_SIZE)
>> #define CONFIGURE_MAXIMUM_POSIX_MUTEXES              rtems_resource_unlimited(10)
>> #define CONFIGURE_MAXIMUM_POSIX_CONDITION_VARIABLES  rtems_resource_unlimited(10)
>> #define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES           rtems_resource_unlimited(10)
>> #define CONFIGURE_UNIFIED_WORK_AREAS
>> #include <rtems/confdefs.h>
>>      struct timespec time1;
>>      struct timespec time2;
>>      uint32_t i = 0;
>>      while (TRUE) {
>>          clock_gettime(CLOCK_REALTIME, &time1);
>>          clock_gettime(CLOCK_REALTIME, &time2);
>>          if (time1.tv_sec == time2.tv_sec) {
>>              if (time2.tv_nsec < time1.tv_nsec) {
>>                  PRINTF("Violation!\n");
>>                  PRINTF("%09u - %09u\n", time1.tv_sec, time1.tv_nsec);
>>                  PRINTF("%09u - %09u\n", time2.tv_sec, time2.tv_nsec);
>>          i++;
>>          if (0 == (i % 1000)) {
>>              PRINTF("Completed %d iterations...\n", i);
>> </code snippet>
>> <output>
>> (gdb) run
>> Completed 1000 iterations...
>> Completed 2000 iterations...
>> Completed 3000 iterations...
>> Violation!
>> 000000000 - 169994000
>> 000000000 - 160002000
>> Completed 4000 iterations...
>> Completed 5000 iterations...
>> Completed 6000 iterations...
>> Violation!
>> 000000000 - 409994000
>> 000000000 - 400002000
>> Completed 7000 iterations...
>> Completed 8000 iterations...
>> Completed 9000 iterations...
>> Completed 10000 iterations...
>> Completed 11000 iterations...
>> Violation!
>> 000000000 - 769993000
>> 000000000 - 760001000
>> </output>
>> I'm running RTEMS 4.10.99 against the LEON3 (GR712RC) BSP.
>> Is this expected behavior, or am I doing something incorrectly?
> No it is not expected.
> What date did you pull the code? Is it up to date?
>> Thanks.
>> Scott
>> Scott Miller | 210-522-4249 | Senior Research Engineer | Southwest Research Institute
>> users mailing list
>> users at rtems.org
