Beaglebone Bootloader
Ketul Shah
ketulshah1993 at gmail.com
Wed Jun 24 06:32:23 UTC 2015
Hi Angelo,
I am attaching link for hello word .img [1]. That you can try. I have
tested it on my BBB working fine. but I used sdcard not the tftp.
Anyways you can check it with your BBB.
Also you can try one more that is for gpio [2] that you can test it without
having requirement of any output on screen. It has user led blinking
program.
[1] https://github.com/ketul93/RTEMS-on-BBB/tree/master/Gettin-Started
[2] https://github.com/ketul93/RTEMS-on-BBB/tree/master/GPIO-Test
Thanks.
Best Regards,
Ketul
On 24 June 2015 at 08:57, Angelo Fraietta <newsgroups at smartcontroller.com.au
> wrote:
> I got back to my defaule beagle by reflashing. However, can someone please
> email me a known working image (say hello) that can be loaded (and
> preferably tested) by tftp. I need to eliminate whether it is the
> executable generated by me or something else.
> Thanks
> On Wed, Jun 24, 2015 at 8:40 AM, Angelo Fraietta <
> newsgroups at smartcontroller.com.au> wrote:
>> My image is not loading.
>> U-Boot SPL 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
>> reading args
>> spl_load_image_fat_os: error reading image args, err - -1
>> reading u-boot.img
>> reading u-boot.img
>> U-Boot 2014.04-00014-g47880f5 (Apr 22 2014 - 13:23:54)
>> I2C: ready
>> DRAM: 512 MiB
>> NAND: 0 MiB
>> MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
>> *** Warning - readenv() failed, using default environment
>> Net: <ethaddr> not set. Validating first E-fuse MAC
>> cpsw, usb_ether
>> Hit any key to stop autoboot: 0
>> gpio: pin 53 (gpio 53) value is 1
>> Card did not respond to voltage select!
>> mmc0(part 0) is current device
>> gpio: pin 56 (gpio 56) value is 0
>> gpio: pin 55 (gpio 55) value is 0
>> gpio: pin 54 (gpio 54) value is 0
>> mmc1(part 0) is current device
>> gpio: pin 54 (gpio 54) value is 1
>> SD/MMC found on device 1
>> reading uEnv.txt
>> 426 bytes read in 4 ms (103.5 KiB/s)
>> gpio: pin 55 (gpio 55) value is 1
>> Loaded environment from uEnv.txt
>> Importing environment from mmc ...
>> Checking if uenvcmd is set ...
>> gpio: pin 56 (gpio 56) value is 1
>> Running uenvcmd ...
>> cpsw Waiting for PHY auto negotiation to complete. done
>> link up on port 0, speed 100, full duplex
>> Using cpsw device
>> TFTP from server 192.168.0.25; our IP address is 192.168.0.53
>> Filename '/hello'.
>> Load address: 0x81000000
>> Loading: #################################################################
>> 4.9 MiB/s
>> done
>> Bytes transferred = 33554432 (2000000 hex)
>> Wrong Image Format for bootm command
>> ERROR: can't get kernel image!
>> uenvcmd was not defined in uEnv.txt ...
>> Booting from nand ...
>> no devices available
>> Bad Linux ARM zImage magic!
>> U-Boot#
>> It would not load the image. So I think my image is bad. Can someone
>> email me the image for the hello example for beagle already
>> I modified the uEnv.txt on the device. Now, however, I have a beagle that
>> is in the uBoot menu and I can't change the eUenv,txt because it will not
>> how up as a drive because it is not booted into linux.
>> How do I get back to beagle linux from u-boot prompt?
>> Thanks
>> On Tue, Jun 23, 2015 at 6:44 PM, Cláudio Silva <claudiodcsilva at gmail.com>
>> wrote:
>>> Hello Angelo,
>>> I am using the following script snippet to generate a u-boot bootable
>>> image from an RTEMS .exe:
>>> https://gist.github.com/cdcs/0c789e9aae9e79200da5
>>> It essentially follows the steps described in Ben's README.
>>> If you are using application=/TICKER in the script, it will try to load
>>> something called TICKER from the tftp root (without any extension).
>>> Did you try with the u-boot that comes preloaded in the BBB?
>>> You can just try boot the linux version provided in the BBB's emmc and
>>> then change the uEnv.txt ("/boot/uboot/uEnv.txt") to your tftp version of
>>> uEnv. You shouldn't need the sdcard.
>>> Best Regards,
>>> Cláudio
>>> On Tue, Jun 23, 2015 at 5:59 AM Angelo Fraietta <
>>>> If it is any help. this is the configuration on my SDCard that loads
>>>> debian linux from SDCard.
>>>> ##Video: Uncomment to override:
>>>> ##see:
>>>> https://git.kernel.org/cgit/linux/kernel/git/torvalds/linux.git/tree/Documentation/fb/modedb.txt
>>>> #kms_force_mode=video=HDMI-A-1:1024x768 at 60e
>>>> ##Enable systemd
>>>> systemd=quiet init=/lib/systemd/systemd
>>>> ##BeagleBone Cape Overrides
>>>> ##BeagleBone Black:
>>>> ##Disable HDMI/eMMC
>>>> #optargs=capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN,BB-BONE-EMMC-2G
>>>> ##Disable HDMI
>>>> ##WIP: v3.13+ capes..
>>>> #cape=lcd4-01
>>>> #cape=
>>>> ##note: the eMMC flasher script relies on the next line
>>>> mmcroot=UUID=8f529ad7-82d1-4d8e-91dc-31e9e2080813 ro
>>>> mmcrootfstype=ext4 rootwait fixrtc
>>>> ##These are needed to be compliant with Angstrom's 2013.06.20 u-boot.
>>>> console=ttyO0,115200n8
>>>> kernel_file=zImage
>>>> initrd_file=initrd.img
>>>> loadaddr=0x82000000
>>>> initrd_addr=0x88080000
>>>> fdtaddr=0x88000000
>>>> initrd_high=0xffffffff
>>>> fdt_high=0xffffffff
>>>> loadkernel=load mmc ${mmcdev}:${mmcpart} ${loadaddr} ${kernel_file}
>>>> loadinitrd=load mmc ${mmcdev}:${mmcpart} ${initrd_addr} ${initrd_file};
>>>> setenv initrd_size ${filesize}
>>>> loadfdt=load mmc ${mmcdev}:${mmcpart} ${fdtaddr} /dtbs/${fdtfile}
>>>> loadfiles=run loadkernel; run loadinitrd; run loadfdt
>>>> mmcargs=setenv bootargs console=tty0 console=${console} ${optargs}
>>>> ${kms_force_mode} root=${mmcroot} rootfstype=${mmcrootfstype} ${systemd}
>>>> uenvcmd=run loadfiles; run mmcargs; bootz ${loadaddr}
>>>> ${initrd_addr}:${initrd_size} ${fdtaddr}
>>>> On Tue, Jun 23, 2015 at 12:59 PM, Angelo Fraietta <
>>>>> I can see I missed a step from Ben's tutorial where it creates the
>>>>> image file.
>>>>> I copied the image to tftp and it did not work
>>>>> I also tried doing out of Bens tutorial the
>>>>> dd if=bone_hello.exe-sdcard.img of=/dev/mmcblk0 bs=4096
>>>>> However, nothing was displayed on my monitor and the three LEDS lit,
>>>>> followed by the light on ethernet port. It did this about three times and
>>>>> then booted into normal BBB linux. It looked to me like it was resetting,
>>>>> however, can't be sure.
>>>>> Is someone able to email me a working image for BBB so I can see it
>>>>> that will boot.
>>>>> Thanks
>>>>> On Tue, Jun 23, 2015 at 8:46 AM, Angelo Fraietta <
>>>>>> Does not boot.
>>>>>> I have u-boot on the SD card. I know it is being called because if I
>>>>>> disconnect the ethernet, it freezes and does not boot. If I remove SDcard
>>>>>> and remove ethernet, it boots normally
>>>>>> I have tftp on 192.168.0.25
>>>>>> My configuration is exactly this
>>>>>> ### BBB : Configuration
>>>>>> ipaddr=192.168.0.53
>>>>>> serverip=192.168.0.25
>>>>>> netmask=255.255.255.0
>>>>>> ### XKY-OS : Configuration
>>>>>> baseaddr=0x81000000
>>>>>> application=/TICKER
>>>>>> ### Boot BBB from network
>>>>>> nfsargs=setenv bootargs console=${console} root=/dev/nfs
>>>>>> nfsroot=${serverip}:${rootpath} rw
>>>>>> ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
>>>>>> xkyboot=run nfsargs; tftp ${baseaddr} ${application}; bootm
>>>>>> ${baseaddr}
>>>>>> uenvcmd=run xkyboot
>>>>>> I have copied ticker.exe to root folder
>>>>>> I tried
>>>>>> application=/TICKER
>>>>>> application=/ticker.exe
>>>>>> application=/TICKER.EXE
>>>>>> Just boots into normal regardless of what I do (except removing
>>>>>> ethernet with SDCard in). Looking at U-boot in display looks the same as
>>>>>> though three was no SDcard. How can I freeze screen to read what it all
>>>>>> says?
>>>>>> I tested my tftp server like this
>>>>>> http://www.gunnalag.com/2013/08/05/how-to-test-tftp-server-from-a-client-system-in-windows/
>>>>>> I did
>>>>>> tftp -i 1923.168.0.25 get ticker.exe
>>>>>> And it worked fine
>>>>>> So if I am using ticker.exe, what should application=/TICKER be? Is
>>>>>> it case sensitive? Does it need .exe at the end? Am I supposed to be using
>>>>>> ticker.exe?
>>>>>> Can someone send me an exe that does load in BBB so I can see if it
>>>>>> is that loads.
>>>>>> Also, I followed tutorial for installing U-boot on an SDCard which
>>>>>> boots linux from SDCard and that works
>>>>>> http://www.armhf.com/boards/beaglebone-black/bbb-sd-install/
>>>>>> Any suggestions would be great
>>>>>> Thanks
>>>>>> On Mon, Jun 22, 2015 at 6:39 PM, Cláudio Silva <
>>>>>> claudiodcsilva at gmail.com> wrote:
>>>>>>> Hi Angelo,
>>>>>>> xkyboot is just a command name that is executed by uenvcmd; you can
>>>>>>> name whatever you want. "XKYAPP2" is the executable name. It should placed
>>>>>>> on the tftp server's root, or otherwise you need to provide the full path
>>>>>>> to it.
>>>>>>> Is your tftp server working correctly? Try to test from a tftp
>>>>>>> client on Linux.
>>>>>>> Best Regards,
>>>>>>> Cláudio
>>>>>>> On Mon, Jun 22, 2015 at 6:51 AM Angelo Fraietta <
>>>>>>>> I am using BBB also
>>>>>>>> I have had a look at what you have provided
>>>>>>>> are XKYAPP2 and xkyboot your app names?
>>>>>>>> Lets say I wanted to boot ticker from tftp server (assume my tftp
>>>>>>>> server has same ip address as yours)
>>>>>>>> I have copied
>>>>>>>> development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/samples/ticker/ticker.exe
>>>>>>>> to the root of my tftp server
>>>>>>>> I am assuming this is entire uEnv.txt What should it look like (I
>>>>>>>> have provided whole of your file here). Thanks
>>>>>>>> ipaddr=192.168.0.202
>>>>>>>> baseaddr=0x81000000
>>>>>>>> application=/XKYAPP2
>>>>>>>> nfsargs=setenv bootargs console=${console} root=/dev/nfs nfsroot=${serverip}:${rootpath} rw ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
>>>>>>>> xkyboot=run nfsargs; tftp ${baseaddr} ${application}; bootm ${baseaddr}
>>>>>>>> uenvcmd=run xkyboot
>>>>>>>> On Fri, Jun 19, 2015 at 6:14 PM, Cláudio Silva <
>>>>>>>>> You should be able to boot RTEMS through TFTP. At least I do it in
>>>>>>>>> the BBB, I assume the white version should work as well. You just have to
>>>>>>>>> change uboot configuration and setup a tftp server.
>>>>>>>>> My current uboot configuration is the following:
>>>>>>>>> https://gist.github.com/cdcs/76c4dd49c2d574bd68cc
>>>>>>>>> Cláudio
>>>>>>>>> On Fri, Jun 19, 2015 at 5:57 AM Chris Johns <chrisj at rtems.org>
>>>>>>>>> wrote:
>>>>>>>>>> On 19/06/2015 1:56 pm, Angelo Fraietta wrote:
>>>>>>>>>> > Those links I posted -- do any of them work with RTEMS?
>>>>>>>>>> I do not know. I have no interested uboot. Maybe someone else
>>>>>>>>>> knows.
>>>>>>>>>> Chris
>>>>>>>>>> _______________________________________________
>>>>>>>>>> users mailing list
>>>>>>>>>> users at rtems.org
>>>>>>>>>> http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150624/dfde8c0e/attachment-0001.html>
