waf build of libbsd produces no exe's (for me)
Gene Smith gds at chartertn.net
Thu Jun 25 00:46:13 UTC 2015
On 06/22/2015 02:00 AM, Gene Smith wrote:
> I have tried to build libbsd using the documented methods from
> README.waf with no success, although the Makefile method seems to work
> fine. Maybe I am doing something obviously wrong in the waf command
> lines that is preventing the testsuite exe's files (.e.g.,
> ping01/ping01.exe) from being produced.
Thanks for pointing out that the waf style build puts the outputs under
build/ with no .exe. I should have seen that.
Anyhow, just want to report that the waf build of realview-pbx-a9-qemu
is working close to ok and identically to the Makefile build. This
includes the manual addition of tests that run tcpdump (modified
netshell01).
There are three minor problems.
1) when tcpdump is run from rtems shell, if "promiscuous" mode is set
(no -p option provided) then the guest crashes or seems to. This is
indicated by lack of ping responses at a remote or local host as soon as
tcpdump is started in rtems shell. I.e., this crashes the guest (since
pings from other host stop):
[/] # tcpdump -i smc0
%s: promiscuous mode %s
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on smc0, link-type EN10MB (Ethernet), capture size 65535 bytes
But this allows pings to continue and tcpdump shows packet info (rtems
guest is 192.168.2.2):
[/] # tcpdump -p -i smc0
00:01:28.117849 IP 192.168.1.132 > 192.168.2.2: ICMP echo request, id
22951, seq 1, length 64
00:01:28.120912 IP 192.168.2.2 > 192.168.1.132: ICMP echo reply, id
2) ctrl-c does not exit tcpdump back to the rtems shell but kills rtems
shell. This was pointed out by Chris.
3) When starting the guest from the command line like this:
qemu-system-arm -M realview-pbx-a9 -m 256M -no-reboot -monitor none
-serial stdio -nographic -net nic -net tap,ifname=tap0,script=no
-kernel build/arm-rtems4.11-realview_pbx_a9_qemu/netshell01
There is a 30-45 second delay after this prints:
smc0: <SMSC LAN91C110FD or LAN91C111FD> on nexus0
Observing the tap0 interface at start up on the local linux host with
tcpdump shows ipv6 activities with no apparent response. Something seems
to be timing out:
sudo tcpdump -i tap0 -vv
tcpdump: listening on tap0, link-type EN10MB (Ethernet), capture size
262144 bytes
19:45:38.277969 IP6 (hlim 1, next-header Options (0) payload length: 36)
:: > ff02::16: HBH (rtalert: 0x0000) (padn) [icmp6 sum ok] ICMP6,
multicast listener report v2, 1 group record(s) [gaddr ff02::1:ff98:f98a
to_ex { }]
19:45:38.450003 IP6 (hlim 1, next-header Options (0) payload length: 36)
to_ex { }]
19:45:38.824033 IP6 (hlim 255, next-header ICMPv6 (58) payload length:
24) :: > ff02::1:ff98:f98a: [icmp6 sum ok] ICMP6, neighbor solicitation,
length 24, who has hplt.dbnet.lan
19:45:39.826110 IP6 (hlim 1, next-header Options (0) payload length: 36)
hplt.dbnet.lan > ff02::16: HBH (rtalert: 0x0000) (padn) [icmp6 sum ok]
ICMP6, multicast listener report v2, 1 group record(s) [gaddr
ff02::1:ff98:f98a to_ex { }]
-gene
