Changes to rtems_shell_script() working directory?
Sun Jun 28 23:23:36 UTC 2015
On June 28, 2015 6:11:05 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
>On 28/06/2015 9:20 pm, Peter Dufault wrote:
>> Does anyone know of changes in how the shell starts up that would
>affect the current working directory?
>Nothing that explains exactly what you are seeing.
>Changes to the environment have been made to support SMP. The previous
>implementation used task variables and these do not work on SMP so we
>had to change the code. I am not sure if this has had an effect in some
>subtle way on your set up.
Another more likely change was Sebastian's work that tightened the permissions on commands. Run the fileio sample and you will see what the difference between living in as root or a normal user is.
>Chris
>_______________________________________________
>users mailing list
>users at rtems.org
>http://lists.rtems.org/mailman/listinfo/users
--joel
