Changes to rtems_shell_script() working directory?
Peter Dufault dufault at hda.com
Mon Jun 29 00:58:25 UTC 2015
> On Jun 28, 2015, at 19:36 , Chris Johns <chrisj at rtems.org> wrote:
> On 29/06/2015 9:23 am, Joel Sherrill wrote:
>> On June 28, 2015 6:11:05 PM CDT, Chris Johns <chrisj at rtems.org> wrote:
>>> On 28/06/2015 9:20 pm, Peter Dufault wrote:
>>>> Does anyone know of changes in how the shell starts up that would
>>> affect the current working directory?
>>> Nothing that explains exactly what you are seeing.
>>> Changes to the environment have been made to support SMP. The previous
>>> implementation used task variables and these do not work on SMP so we
>>> had to change the code. I am not sure if this has had an effect in some
>>> subtle way on your set up.
>> Another more likely change was Sebastian's work that tightened the permissions on commands. Run the fileio sample and you will see what the difference between living in as root or a normal user is.
> Yes perms can lock you out. If the script has not had the equivalent of
> "chmod +x script" it will not run.
> FYI I am using those perms in production to restrict user access. In one
> product we have 3 levels and it works well. The only issue is the need
> to add a C interface to change the perms and ownership.
> Chris
What I really wonder is why it worked before.  I made the change I outlined previously (move the “chdir” above the “fopen”) and it now works, the shells current working directory is evidently “/“ until the “chdir”.
Is anyone else using rtems_shell_script() and seeing this?
It isn’t
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
