Attempting to build an app for Beaglebone
Angelo Fraietta
newsgroups at smartcontroller.com.au
Mon Jun 29 04:18:45 UTC 2015
Greetings
I have been able to successfully able to build and run RTEMS samples using
Ben's tutorial at
http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
with a few mods and am able to run using tftp
However, I am having difficulty using my own make file to build an app.
I have added RTEMS_MAKEFILE_PATH to my environment and added
PATH=$PATH:/home/angelo/development/rtems/4.11/bin
When I run my makefile, I get an error
Makefile:41: /opt/rtems-4.11/make/leaf.cfg: No such file or directory
make: *** No rule to make target `/opt/rtems-4.11/make/leaf.cfg'. Stop.
It looks to me like RTEMS_ROOT is not being set properly (I could be wrong)
Find below makefile contents
EXEC=gpio.exe
# C source names, if any, go here -- minus the .c
C_PIECES= init
C_FILES=$(C_PIECES:%=%.c)
C_O_FILES=$(C_PIECES:%=${ARCH}/%.o)
# C++ source names, if any, go here -- minus the .cc
CC_PIECES=
CC_FILES=$(CC_PIECES:%=%.cpp)
CC_O_FILES=$(CC_PIECES:%=${ARCH}/%.o)
H_FILES=
# Assembly source names, if any, go here -- minus the .S
S_PIECES=
S_FILES=$(S_PIECES:%=%.S)
S_O_FILES=$(S_FILES:%.S=${ARCH}/%.o)
SRCS=$(C_FILES) $(CC_FILES) $(H_FILES) $(S_FILES)
OBJS=$(C_O_FILES) $(CC_O_FILES) $(S_O_FILES)
PGMS=${ARCH}/$(EXEC) #${ARCH}/xxx-another-one
# List of RTEMS managers to be included in the application goes here.
# Use:
# MANAGERS=all
# to include all RTEMS managers in the application.
MANAGERS=io event message rate_monotonic semaphore timer
include $(RTEMS_MAKEFILE_PATH)/Makefile.inc
include $(RTEMS_CUSTOM)
include $(RTEMS_ROOT)/make/leaf.cfg
# (OPTIONAL) Add local stuff here using +=
DEFINES +=
CPPFLAGS +=
XCPPFLAGS +=
CFLAGS +=
# CFLAGS_DEBUG_V are used when the `make debug' target is built.
# To link your application with the non-optimized RTEMS routines,
# uncomment the following line:
# CFLAGS_DEBUG_V += -qrtems_debug
LD_PATHS += #xxx-your-EXTRA-library-paths-go-here, if any
LD_LIBS +=
# Add the following code when attempting to strip down in size
#LDFLAGS += -Wl,'-gc-sections'
# Add your list of files to delete here. The config files
# already know how to delete some stuff, so you may want
# to just run 'make clean' first to see what gets missed.
# 'make clobber' already includes 'make clean'
CLEAN_ADDITIONS +=
CLOBBER_ADDITIONS +=
all: ${ARCH} $(SRCS) $(PGMS)
${ARCH}/$(EXEC): ${OBJS} ${LINK_FILES}
$(make-cxx-exe)
# Install the program(s), appending _g or _p as appropriate.
# for include files, just use $(INSTALL_CHANGE)
install: all
$(INSTALL_VARIANT) -m 555 ${PGMS} ${PROJECT_RELEASE}/bin
Any ideas?
Thanks
URL: <http://lists.rtems.org/pipermail/users/attachments/20150629/0ff748ce/attachment.html>
