"error: environment PATH invalid path: ." with Building a Tools set with RTEMS
Mon Jun 29 21:21:51 UTC 2015
To wrap this up, including . in your PATH has long been considered bad from a security viewpoint
On June 29, 2015 4:16:46 PM CDT, Alvin Dulcan <Alvin.Dulcan at sslmda.com> wrote:
>Thanks,
>That was it.
>Alvin
>-----Original Message-----
>From: Karel Gardas [mailto:karel.gardas at centrum.cz]
>Sent: Monday, June 29, 2015 12:23 PM
>To: Alvin Dulcan
>Cc: users at rtems.org
>Subject: Re: "error: environment PATH invalid path: ." with Building a
>Yes, just remove dot (current dir) from your PATH...
>Karel
>On 06/29/15 09:06 PM, Alvin Dulcan wrote:
>> When I try to do the first step of a quick start on
>> https://devel.rtems.org/wiki/Developer/Tools/RSB:
>> $ cd
>> $ mkdir -p development/rtems/rsb
>> $ cd development/rtems/rsb
>> $ git clone git://git.rtems.org/rtems-source-builder.git
>> $ cd rtems-source-builder
>> $ cd rtems
>> $ ../source-builder/sb-set-builder
>> --prefix=$HOME/development/rtems/4.11
>> 4.11/rtems-sparc
>> I get:
>> cat rsb-log-20150629-184804.txt
>> RTEMS Source Builder - Set Builder, v0.5.0
>> Command Line: ../source-builder/sb-set-builder
>> --prefix=/home/itacs/development/rtems/4.11 4.11/rtems-sparc
>> Python: 2.6.6 (r266:84292, Jun 18 2012, 14:18:47) [GCC 4.4.6 20110731
>> (Red Hat 4.4.6-3)]
>> I installed all of the packages for CENTOS (release 6.2)
>> Thanks,
>> Alvin
>> -- This message (including any attachments) may contain confidential
>> information intended for a specific individual and purpose. If you
>are
>> not the intended recipient, you should delete this message and any
>> attachments.
>> users mailing list
>> users at rtems.org
>information intended for a specific individual and purpose. If you are
>attachments.
>users mailing list
>users at rtems.org
--joel
