libbsd.txt "test runner" realview_pbx_a9_qemu
Wed Jun 3 07:07:07 UTC 2015
Hello Gene,
the test runner are available via the rtems-testing repository.  You may
need the attached Qemu patches.
On 02/06/15 21:35, Gene Smith wrote:
> Have been attempting to follow the instructions in libbsd.txt and it
> mentions a "test runner" but doesn't say what that means. Based on the
> contents of config.inc, it appears to be the bsp name,
> realview_pbx_a9_qemu, but make install of libbsd does not seem to
> produce a file with that name.
> I also assume I may also need qemu installed but not sure.
> Under realview-pbx-a9 bsp there are instructions for building qemu
> from a particular git snapshot:
> git checkout a1bff71c56f2d1048244c829b63797940dd4ba0e
> However, for me the qemu build fails with this snapshot. But if I
> build from
> git checkout master
> qemu builds OK.
> Any help or pointers on this would be appreciated.
> -gene
> users mailing list
> users at rtems.org
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20150603/8e0b1a67/attachment-0004.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20150603/8e0b1a67/attachment-0005.bin>
