error while compling libbsd (cannot find rtems/timecounter.h)
Chan Kim
ckim at etri.re.kr
Tue Jun 9 10:56:10 UTC 2015
> You need the latest RSB based tool chain and RTEMS version. I think you are
> only able to build on SPARC using the waf builder for libbsd. I am not sure if
> there is a driver for SPARC in libbsd currently.
As you said, using latest toolchain and RTEMS source it passes that rtems/timercounter.h error, but eventually I met with the "missing rtems/pci.h " error. So I'll try using waf.
Thanks!
Chan
보낸 사람 : "Sebastian Huber" <sebastian.huber at embedded-brains.de>
보낸 날짜 : 2015-06-09 14:13:28 ( +09:00 )
받는 사람 : 김찬 <ckim at etri.re.kr>
참조 : users at rtems.org <users at rtems.org>
제목 : Re: error while compling libbsd (cannot find rtems/timecounter.h)
----- Chan Kim schrieb:
> Hello,
> I already have rtems4.11 built for our BSP. and trying to install libbsd, I followed libbsd.txt file config.inc.
> I believe my toolchain uses Binutils 2.24, Newlib 2.1.0. and linkcmds file has the rtemsroset and rtemsrwset specified.
> My config.inc is as below.
You need the latest RSB based tool chain and RTEMS version. I think you are only able to build on SPARC using the waf builder for libbsd. I am not sure if there is a driver for SPARC in libbsd currently.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
