attaching an interrupt in beaglebone bsp
Angelo Fraietta newsgroups at smartcontroller.com.au
Wed Jun 17 07:24:59 UTC 2015
Fails here during build
make[6]: Leaving directory
`/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/syscall01'
Making all in dl01
make[6]: Entering directory
`/home/angelo/development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/libtests/dl01'
arm-rtems4.11-gcc -B../../../../../beagleboneblack/lib/ -specs bsp_specs
-qrtems -DHAVE_CONFIG_H -I.
-I../../../../../../../rtems-src/c/src/../../testsuites/libtests/dl01 -I..
 -I../../../../../../../rtems-src/c/src/../../testsuites/libtests/../support/include
  -mcpu=cortex-a8 -O2 -g -Wall -Wmissing-prototypes
-Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT
dl-o1.o -MD -MP -MF .deps/dl-o1.Tpo -c -o dl-o1.o
../../../../../../../rtems-src/c/src/../../testsuites/libtests/dl01/dl-o1.c
mv -f .deps/dl-o1.Tpo .deps/dl-o1.Po
w -f dl.tar dl-o1.o
 22:50:56 up 10 days, 16:36,  1 user,  load average: 0.91, 0.56, 0.27
USER     TTY        LOGIN@   IDLE   JCPU   PCPU WHAT
../../../../../../tools/build/rtems-bin2c -C dl.tar dl-tar.c
cannot open dl.tar for reading
make[6]: *** [dl-tar.c] Error 1
On Wed, Jun 17, 2015 at 3:57 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 17/06/2015 3:43 pm, Angelo Fraietta wrote:
> > I did a commit but when I try try to push and it goes
> > angelo at debian
> :~/development/rtems/sources/rtems-source-builder/bare/config/devel$
> > git push
> > Username:
> > Password:
> > error: The requested URL returned error: 403 while accessing
> > https://github.com/bengras/rtems-source-builder.git/info/refs
> I have not used github to develop with so what follows may be complete
> nonsense.
> Try making a clone on github under your account and then cloning that to
> your local machine. You should be able to push to your personal repo.
> Once pushed you should be able to make a pull request on Ben.
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20150617/55288fb1/attachment-0002.html>
