attaching an interrupt in beaglebone bsp
Angelo Fraietta
newsgroups at smartcontroller.com.au
Fri Jun 19 03:54:50 UTC 2015
You will have to step me through what to do to make the patch and upload
it. There were other dependencies also that need to be added to it also.
On Fri, Jun 19, 2015 at 12:41 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 18/06/2015 4:03 pm, Angelo Fraietta wrote:
> > That worked. I have the test suites built successfully. I just need to
> > dd to a disk and see if it works.
> Excellent.
> > So I think we need to add the other dependency checks in sb-check to
> > test for the dependencies that did not show up as missing.
> Would you like to create patch ? It means adding pax to
> source-builder/defaults.mc.
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20150619/089c16da/attachment-0002.html>
