Beaglebone Bootloader
Angelo Fraietta newsgroups at smartcontroller.com.au
Mon Jun 22 05:46:00 UTC 2015
I can't find that file. What is the path?
Thanks
On Sat, Jun 20, 2015 at 7:51 AM, Ben Gras <beng at shrike-systems.com> wrote:
> Yes, you can configure uboot on the beaglebones to boot RTEMS over the
> network. I've done it a few times on both the black and the white.
> Take a look at the readme in the beagle/ dir, the uboot config is
> there.
> On Fri, Jun 19, 2015 at 12:12 AM, Angelo Fraietta
> <newsgroups at smartcontroller.com.au> wrote:
> > Greetings
> > Has anyone had a look at a bootloader for the beagle with RTEMS. The
> method
> > that these guys are using removed the requirement of having to write to a
> > sdcard each time
> > http://m.linuxjournal.com/content/handy-u-boot-trick
> > https://github.com/RIOT-OS/RIOT/wiki/Board:-BeagleBone
> > Thanks
URL: <http://lists.rtems.org/pipermail/users/attachments/20150622/c4900fdd/attachment-0002.html>
