Beaglebone Bootloader
Angelo Fraietta
newsgroups at smartcontroller.com.au
Mon Jun 22 05:51:11 UTC 2015
I am using BBB also
I have had a look at what you have provided
are XKYAPP2 and xkyboot your app names?
Lets say I wanted to boot ticker from tftp server (assume my tftp server
has same ip address as yours)
I have copied
development/rtems/b-beagle/arm-rtems4.11/c/beagleboneblack/testsuites/samples/ticker/ticker.exe
to the root of my tftp server
I am assuming this is entire uEnv.txt What should it look like (I have
provided whole of your file here). Thanks
### BBB : Configuration
ipaddr=192.168.0.202
serverip=192.168.0.2
netmask=255.255.255.0
### XKY-OS : Configuration
baseaddr=0x81000000
application=/XKYAPP2
### Boot BBB from network
nfsargs=setenv bootargs console=${console} root=/dev/nfs
nfsroot=${serverip}:${rootpath} rw
ip=${ipaddr}:${serverip}:${serverip}:${netmask}::eth0:off
xkyboot=run nfsargs; tftp ${baseaddr} ${application}; bootm ${baseaddr}
uenvcmd=run xkyboot
On Fri, Jun 19, 2015 at 6:14 PM, Cláudio Silva <claudiodcsilva at gmail.com>
wrote:
> You should be able to boot RTEMS through TFTP. At least I do it in the
> BBB, I assume the white version should work as well. You just have to
> change uboot configuration and setup a tftp server.
> My current uboot configuration is the following:
> https://gist.github.com/cdcs/76c4dd49c2d574bd68cc
> Cláudio
> On Fri, Jun 19, 2015 at 5:57 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 19/06/2015 1:56 pm, Angelo Fraietta wrote:
>> > Those links I posted -- do any of them work with RTEMS?
>> I do not know. I have no interested uboot. Maybe someone else knows.
>> Chris
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150622/37cb8e28/attachment-0002.html>
