SMP on Xilinx Zynq
Mon Mar 2 21:30:34 UTC 2015
On 2/03/2015 3:42 am, Joel Sherrill wrote:
> On March 1, 2015 10:40:41 AM CST, "Maldonado, Sergio E." <smaldona at slac.stanford.edu> wrote:
>> Problem solved.  My MMU configuration did not have the RTEMS workspace
>> memory set with the shared attribute.
> Is this something the BSP could have detected and printed a helpful message?
I am not sure there much value in adding something like this. It is
similar to a broken linkercmd file. You tend to sort this stuff out and
then leave it and after that the helpful code becomes an overhead.
