Questions about the implementation of RMS on rtems
Wed Mar 25 14:11:23 UTC 2015
You might like to try reading a text book on real-time systems, such
as Jane Liu's book. If you have accurate WCET measurements then RMS
works by assigning periods to tasks, computing U < 0.69 (or whatever),
and assigning priorites inversely to periods. Then you have to ensure
that the periods are enforced. RTEMS has mechanisms for creating the
periodic timers and to return a status code in case of an overrun. It
is up to the application to detect an overrun and account for it in
this case.
Gedare
On Wed, Mar 25, 2015 at 8:00 AM, yuanbin zhou <hduffddybz at gmail.com> wrote:
> Sorry for late reply because of paper reading, taking courses and
> unimportant things.
>> >2. How to use the processor utilization rule and first deadline rule to
>> >guarantee as more as possible tasks to run since the execution time of
>> >each tasks cannot accurately know before the task run?
>> This is in the users manual and in the original 1973 JACM paper
>> referenced.
>> It also includes the assumptions about the underlying OS and environment.
> Recently I read the paper written by C.L.LIU(Scheduling Algorithms for
> Multiprogramming in a Hard-Real-Time Environment), this paper talks about
> the algorithm of RM Scheduling and the proof of it.But now what I am more
> concerned about is how to  apply this rule to the analysis of real-time
> system.Maybe the analysis of the schedulability of this this system should
> be done by off-line tools before system start up.But the analysis of
> worse-case execution time may not correct which may result in execution
> overrun,so some papers put forward some resource reservation mechanisms to
> solve this problem.So confused about the paper reading, so I want to know
> how to handle this situation in "rtems"since that I cannot figure out any
> information from the user manual.
>> >3. Obey the rate monotonic scheduling algorithm, we can easily set the
>> >priority of every periodic tasks. But in many applications, it consists
>> >both periodic and aperiodic tasks(such as irregular interrupt which is
>> >also essential task), so how to handle the priority setting for this
>> >situation or just set the irregular task's priority by manual?
>> You need to do some academic paper research. There are a number of papers
>> describing how to address various task patterns
> I read some papers about the handle of periodic tasks and aperiodic
> tasks.There existed two kinds of method to solve this problem.
> First:the system can schedule the aperiodic tasks by periodic server which
> allocates a certain amount of budget for aperiodic execution in every period
> time.
>  second:there is no benefit for the periodic tasks to complete their tasks
> much before their deadlines. So when the aperiodic task coming, it steals
> the available slack from the periodic tasks and execute it as soon as
> possible.
> So can give more detail about the implementation of this in rtems which I
> cannot find anything from the user manual and it is really complicated to
> find the corresponding source file for all the source files located in only
> one directory!
> users mailing list
> users at rtems.org
