Build with RSB - I got lost.
Thu Mar 26 14:48:32 UTC 2015
On March 26, 2015 9:45:29 AM CDT, Anand Krishnan <anandkp92 at gmail.com> wrote:
>On Thu, Mar 26, 2015 at 8:07 PM, Joel Sherrill
><joel.sherrill at oarcorp.com> wrote:
>On 03/26/2015 09:29 AM, Stanisław Grzeszczak wrote:
>Q 1: Do the mismatched paths mean that the build went wrong? Or should
>I just fix the paths by hand, or move the lib/include folders?
>(Q 2: Should the examples have already been built along with everything
>else?)
>If you configured and built RTEMS using configure, make, etc and
>configured with
>--enable-tests=samples, the executable was there and has symbolic
>information in it.
>I have no idea what you did. If you used a native gcc or tried to
>compile it by hand,
>then it didn't work.
>When I had tried, I had to change the path variable to the directory
>where RSB built the tool-set.
>This was the code for I had to use: export
>PATH=/home/development/rtems/4.11/bin:$PATH , before I ran bootstrap.
What is the contents of that bin directory?
Do "type autoconf" and make sure you are getting the one for RTEMS.
>-- Joel Sherrill
>Ask me about RTEMS: a free RTOS
>Support and Training Available
>_______________________________________________
>users mailing list
>users at rtems.org
>http://lists.rtems.org/mailman/listinfo/users
--joel
