Build with RSB - I got lost.
Anand Krishnan
anandkp92 at gmail.com
Thu Mar 26 15:07:51 UTC 2015
It did run for me!
I just had to export the local bin path as it was on my machine.
On Thu, Mar 26, 2015 at 8:34 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 03/26/2015 09:58 AM, Anand Krishnan wrote:
>> On Thu, Mar 26, 2015 at 8:18 PM, Joel Sherrill <joel.sherrill at oarcorp.com
>> <mailto:joel.sherrill at oarcorp.com>> wrote:
>> On March 26, 2015 9:45:29 AM CDT, Anand Krishnan
>> <anandkp92 at gmail.com <mailto:anandkp92 at gmail.com>> wrote:
>> >On Thu, Mar 26, 2015 at 8:07 PM, Joel Sherrill
>> ><joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>>
>> wrote:
>> >On 03/26/2015 09:29 AM, Stanisław Grzeszczak wrote:
>> >Q 1: Do the mismatched paths mean that the build went wrong? Or
>> should
>> >I just fix the paths by hand, or move the lib/include folders?
>> >(Q 2: Should the examples have already been built along with
>> everything
>> >else?)
>> >If you configured and built RTEMS using configure, make, etc and
>> >configured with
>> >--enable-tests=samples, the executable was there and has symbolic
>> >information in it.
>> >I have no idea what you did. If you used a native gcc or tried to
>> >compile it by hand,
>> >then it didn't work.
>> >When I had tried, I had to change the path variable to the directory
>> >where RSB built the tool-set.
>> >This was the code for I had to use: export
>> >PATH=/home/development/rtems/4.11/bin:$PATH , before I ran
>> bootstrap.
>> What is the contents of that bin directory?
>> Do "type autoconf" and make sure you are getting the one for RTEMS.
>> The bin directory had all the tools created for sparc:
>> sparc-rtems4.11-gcc, sparc-rtems4.11-gdb among others.
>> It was created after I build the sparc tool-set.
>> Then when you are at the top of the rtems source tree,
> ./bootstrap should just run without trouble based on you putting
> that directory at the head of your PATH.
> Then.... something like this
> $ cd ..
> $ mkdir b-sis
> $ cd b-sis
> $ ../rtems/configure --target=sparc-rtems4.11 --enable-rtemsbsp=sis
> ... that should end with a message indicating sis is a BSP to be built ...
> $ make
> $ find . -name "*.exe"
> ... that should print a handful of executables..
> $ sparc-rtems4.11-gdb `find . -name hello.exe`
> .... gdb stuff ...
> (gdb) tar sim
> (gdb) load
> (gdb) run
> ... output...
>> >-- Joel Sherrill
>> >Ask me about RTEMS: a free RTOS
>> >Support and Training Available
>> >_______________________________________________
>> >users mailing list
>> >users at rtems.org <mailto:users at rtems.org>
>> >http://lists.rtems.org/mailman/listinfo/users
>> --joel
> -- Joel Sherrill
URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/efcd6432/attachment.html>
