Build with RSB - I got lost.
Stanisław Grzeszczak
stgrzeszczak at gmail.com
Thu Mar 26 16:01:28 UTC 2015
@All,
It's all set up and working now.
Thank you for your invaluable input,
Stanislaw
2015-03-26 16:11 GMT+01:00 Joel Sherrill <joel.sherrill at oarcorp.com>:
> On 03/26/2015 10:07 AM, Anand Krishnan wrote:
>> It did run for me!
>> I just had to export the local bin path as it was on my machine.
> Great.
> Just so this thread ends with another piece of advice. I spent months
> helping someone on and off and it turned out that they weren't setting
> the PATH in each window. All sounded great on the phone. When we
> set up a video conference, I saw the mistake in 30 seconds. :)
>> On Thu, Mar 26, 2015 at 8:34 PM, Joel Sherrill <joel.sherrill at oarcorp.com
>> <mailto:joel.sherrill at oarcorp.com>> wrote:
>> On 03/26/2015 09:58 AM, Anand Krishnan wrote:
>> On Thu, Mar 26, 2015 at 8:18 PM, Joel Sherrill
>> <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>
>> <mailto:joel.sherrill at oarcorp.com>>> wrote:
>> On March 26, 2015 9:45:29 AM CDT, Anand Krishnan
>> <anandkp92 at gmail.com <mailto:anandkp92 at gmail.com>
>> <mailto:anandkp92 at gmail.com <mailto:anandkp92 at gmail.com>>> wrote:
>> >On Thu, Mar 26, 2015 at 8:07 PM, Joel Sherrill
>> >On 03/26/2015 09:29 AM, Stanisław Grzeszczak wrote:
>> >Q 1: Do the mismatched paths mean that the build went wrong?
>> Or should
>> >I just fix the paths by hand, or move the lib/include folders?
>> >(Q 2: Should the examples have already been built along with
>> everything
>> >else?)
>> >If you configured and built RTEMS using configure, make, etc and
>> >configured with
>> >--enable-tests=samples, the executable was there and has symbolic
>> >information in it.
>> >I have no idea what you did. If you used a native gcc or tried to
>> >compile it by hand,
>> >then it didn't work.
>> >When I had tried, I had to change the path variable to the
>> directory
>> >where RSB built the tool-set.
>> >This was the code for I had to use: export
>> >PATH=/home/development/rtems/4.11/bin:$PATH , before I ran
>> bootstrap.
>> What is the contents of that bin directory?
>> Do "type autoconf" and make sure you are getting the one
>> for RTEMS.
>> The bin directory had all the tools created for sparc:
>> sparc-rtems4.11-gcc, sparc-rtems4.11-gdb among others.
>> It was created after I build the sparc tool-set.
>> Then when you are at the top of the rtems source tree,
>> ./bootstrap should just run without trouble based on you putting
>> that directory at the head of your PATH.
>> Then.... something like this
>> $ cd ..
>> $ mkdir b-sis
>> $ cd b-sis
>> $ ../rtems/configure --target=sparc-rtems4.11
>> --enable-rtemsbsp=sis --enable-tests=samples
>> ... that should end with a message indicating sis is a BSP to be
>> built ...
>> $ make
>> $ find . -name "*.exe"
>> ... that should print a handful of executables..
>> $ sparc-rtems4.11-gdb `find . -name hello.exe`
>> .... gdb stuff ...
>> (gdb) tar sim
>> (gdb) load
>> (gdb) run
>> ... output...
>> >-- Joel Sherrill
>> >Ask me about RTEMS: a free RTOS
>> >Support and Training Available
>> >_______________________________________________
>> >users mailing list
>> >users at rtems.org <mailto:users at rtems.org>
>> <mailto:users at rtems.org <mailto:users at rtems.org>>
>> >http://lists.rtems.org/mailman/listinfo/users
>> --joel
>> -- -- Joel Sherrill
> -- Joel Sherrill
URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/b271a957/attachment.html>
