Build with RSB - I got lost.
Anand Krishnan anandkp92 at gmail.com
Thu Mar 26 14:45:29 UTC 2015
On Thu, Mar 26, 2015 at 8:07 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On 03/26/2015 09:29 AM, Stanisław Grzeszczak wrote:
> Q 1: Do the mismatched paths mean that the build went wrong? Or should I
>> just fix the paths by hand, or move the lib/include folders?
>> (Q 2: Should the examples have already been built along with everything
>> else?)
>>  If you configured and built RTEMS using configure, make, etc and
> configured with
> --enable-tests=samples, the executable was there and has symbolic
> information in it.
> I have no idea what you did. If you used a native gcc or tried to compile
> it by hand,
> then it didn't work.
When I had tried, I had to change the path variable to the directory where
RSB built the tool-set.
This was the code for I had to use: export
PATH=/home/development/rtems/4.11/bin:$PATH , before I ran bootstrap.
-- Joel Sherrill
Ask me about RTEMS: a free RTOS
Support and Training Available
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/567b9b80/attachment-0002.html>
