Build with RSB - I got lost.
    Anand Krishnan
    anandkp92 at gmail.com
    Thu Mar 26 14:58:40 UTC 2015
On Thu, Mar 26, 2015 at 8:18 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
wrote:
> On March 26, 2015 9:45:29 AM CDT, Anand Krishnan <anandkp92 at gmail.com>
> wrote:
> >On Thu, Mar 26, 2015 at 8:07 PM, Joel Sherrill
> ><joel.sherrill at oarcorp.com> wrote:
> >On 03/26/2015 09:29 AM, Stanisław Grzeszczak wrote:
> >Q 1: Do the mismatched paths mean that the build went wrong? Or should
> >I just fix the paths by hand, or move the lib/include folders?
> >(Q 2: Should the examples have already been built along with everything
> >else?)
> >If you configured and built RTEMS using configure, make, etc and
> >configured with
> >--enable-tests=samples, the executable was there and has symbolic
> >information in it.
> >I have no idea what you did. If you used a native gcc or tried to
> >compile it by hand,
> >then it didn't work.
> >When I had tried, I had to change the path variable to the directory
> >where RSB built the tool-set.
> >This was the code for I had to use: export
> >PATH=/home/development/rtems/4.11/bin:$PATH , before I ran bootstrap.
> What is the contents of that bin directory?
> Do "type autoconf" and make sure you are getting the one for RTEMS.
> The bin directory had all the tools created for sparc:
sparc-rtems4.11-gcc, sparc-rtems4.11-gdb among others.
It was created after I build the sparc tool-set.
> >-- Joel Sherrill
> >Ask me about RTEMS: a free RTOS
> >Support and Training Available
> >_______________________________________________
> >users mailing list
> >users at rtems.org
> >http://lists.rtems.org/mailman/listinfo/users
> --joel
URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/1b8069e4/attachment-0002.html>
