Compilation error of rtems for sparc-leon2 with multilib enabled
Sat May 2 15:48:00 UTC 2015
On May 2, 2015 10:41:35 AM CDT, Jan Sommer <soja-misc at aries.uberspace.de> wrote:
>Has someone else be able to reproduce this behaviour?
>I now tried to build it in a fresh VM and using a combiler build by the
>rsb,
>but still no luck.
The head of the tree builds fine for me with the latest RSB tools.
What is the output of sparc-rtems4.11-gcc --version?
What is your host?
What is your configure command for RTEMS?
What is your PATH?
Hopefully we can spot something that way.
>Am Samstag, 25. April 2015, 12:08:17 schrieb Joel Sherrill:
>> On April 25, 2015 11:47:05 AM EDT, Jan Sommer
>wrote:
>> >Am Samstag, 25. April 2015, 11:25:02 schrieben Sie:
>> >> A large patch came in from Gaisler. You probably need to bootstrap
>> >from the
>> >> top of the tree and build from scratch.
>> >> With that patch set merged, the RTEMS.org and Gaisler RTEMS trees
>> >should be
>> >> synchronized.
>> >I cloned the repo into a new directory to make sure that I have a
>clean
>> >repository and ran ./bootstrap in it, but the problem still exists.
>> >I also boostrapped everytime after I checked out a different commit.
>> Weird. I built all BSPs successfully except a few that I posted about
>> yesterday.
>> I am out of town and answering from my phone. Perhaps someone else
>has an
>> idea.
>> >Or do you mean I need to rebuild the cross compiler too?
>> No. You shouldn't have to rebuild tools. There haven't been any
>changes
>> there recently.
>> >Best regards,
>> >   Jan
>> >> --joel
>> --joel
--joel
