Compilation error of rtems for sparc-leon2 with multilib enabled
Sat May 2 16:09:00 UTC 2015
On May 2, 2015 11:00:55 AM CDT, Jan Sommer <soja-misc at aries.uberspace.de> wrote:
>Am Samstag, 2. Mai 2015, 10:48:00 schrieb Joel Sherrill:
>> The head of the tree builds fine for me with the latest RSB tools.
>> What is the output of sparc-rtems4.11-gcc --version?
>sparc-rtems4.11-gcc (GCC) 4.9.2 20141030 (RTEMS 4.11, RSB
>b65c131f2e11e352fde6efa0ec2fe5000dad3a4a-modified, Newlib
>2.2.0.20150323)
>Copyright (C) 2014 Free Software Foundation, Inc.
>This is free software; see the source for copying conditions.  There is
>NO
>warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
>PURPOSE.
>Don't know why it says modified there, but git status shows no local
>changes
>to the rsb-repository.
>> What is your host?
>Kubuntu 15.04 64bit
>> What is your configure command for RTEMS?
>../rtems-git/configure --target=sparc-rtems4.11 --enable-rtemsbsp=leon2
>enable-tests=samples --enable-networking --enable-posix
>--enable-multilib --
>enable-rdbg --enable-cxx --prefix=/home/jan/workspace/rtems-
>pi/development/rtems/rtems/bsps/4.11
>It works if I don't use --enable-multilib
That's the issue. A normal BSP build doesn't turn that on. It was added long ago as a testing way to ensure the cpukit could be successfully compiled for all CPU model variants gcc knows even if we don't have a BSP that really uses it or if the odd combination even exists in silicon.
Disable that and the leon2 will build.
Out of curiosity, what combination isn't building?
>> What is your PATH?
>pi/development/rtems/./compiler/4.11/bin/:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
>> Hopefully we can spot something that way.
>I also added the complete build log.
>> >Am Samstag, 25. April 2015, 12:08:17 schrieb Joel Sherrill:
>> >> On April 25, 2015 11:47:05 AM EDT, Jan Sommer
>> >wrote:
>> >> >Am Samstag, 25. April 2015, 11:25:02 schrieben Sie:
>> >> >> A large patch came in from Gaisler. You probably need to
>bootstrap
>> >> >from the
>> >> >> top of the tree and build from scratch.
>> >> >> With that patch set merged, the RTEMS.org and Gaisler RTEMS
>trees
>> >> >should be
>> >> >> synchronized.
>> >> >I cloned the repo into a new directory to make sure that I have a
>> >clean
>> >> >repository and ran ./bootstrap in it, but the problem still
>exists.
>> >> >I also boostrapped everytime after I checked out a different
>commit.
>> >> Weird. I built all BSPs successfully except a few that I posted
>about
>> >> yesterday.
>> >> I am out of town and answering from my phone. Perhaps someone else
>> >has an
>> >> idea.
>> >> >Or do you mean I need to rebuild the cross compiler too?
>> >> No. You shouldn't have to rebuild tools. There haven't been any
>> >changes
>> >> there recently.
>> >> >Best regards,
>> >> >   Jan
>> >> >> --joel
>> >> --joel
>> --joel
--joel
