[rtems-libbsd] Building for zynq?
Sebastian Huber
Wed May 6 06:23:09 UTC 2015
Chris updated the RSB to use a new Newlib snapshot, so it should work
with the current RSB tool chain for RTEMS 4.11.
On 29/04/15 12:41, Sebastian Huber wrote:
> You need the lasted Newlib Git master version or you wait for the next
> Newlib snapshot (should be available in the next couple of days).
> ----- Jonathan Brandmeyer <jonathan.brandmeyer at gmail.com> schrieb:
> The libbsd build has now failed on a new error: The header file
> sys/_stdint.h cannot be found for use by the libutil library and tools
> that use it. I note that sys/sys/stdint.h has a #ifndef __rtems__
> wrap-around for that file's reference to <sys/_stdint.h>.
> Replacing the #include with <stdint.h> instead does work around the
> problem, but I wonder if there isn't some other missing dependency.
> This was with a fresh update of both rtems-source-builder,
> rtems-libbsd, and rtems mainline source as of this morning.
> Thanks,
> -Jonathan Brandmeyer
> On Tue, Apr 28, 2015 at 11:31 AM, Jonathan Brandmeyer
> <jonathan.brandmeyer at gmail.com <mailto:jonathan.brandmeyer at gmail.com>>
> wrote:
> Thanks. My toolchain was a few months old, and its update is
> proceeding. I began the update with a simple git pull followed by
> re-running the sb-set-builder program, which is continuing to run
> as I write this. However, I did not explicitly clean the build or
> start from a fresh git checkout of the rtems-source-builder. Will
> the sb-set-builder tool do The Right Thing in the "recursive make
> considered harmful" sense with regard to dependency tracking?
> Phrased differently, is supporting an in-place update an
> explicitly supported usage mode for sb-set-builder, or am I
> expected to start over from scratch on a new build?
> Thanks,
> Jonathan Brandmeyer
> On Tue, Apr 28, 2015 at 8:18 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
> Hello Jonathan,
> you need the latest tools (Newlib in particular must be the up
> to date) to build the libbsd. The Xilinx Zynq is supported.
> <mailto:jonathan.brandmeyer at gmail.com>> schrieb:
> I'm trying to build rtems-libbsd targeting
> xilinx_zynq_zedboard and/or xilinx_zynq_qemu in order to test
> out networking with libbsd. At least two files/types related
> to time are missing:
> rtemsbsd/include/rtems/bsd/sys/resource.h includes
> <sys/_timeval.h> which is not present in RTEMS, my BSP, or
> libbsd. Numerous files then reference sys/resource.h
> freebsd/sys/opencrypto/cryptodev.h requests 'struct bintime'
> to be a member, which is an incomplete type. Again, this type
> is not provided by RTEMS, my BSP, or libbsd.
> Does libbsd work for the ARM Xilinx targets, and if so, what
> can I do about libbsd's sense of time?
> Thanks,
> Jonathan Brandmeyer
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail :sebastian.huber at embedded-brains.de <http://lists.rtems.org/mailman/listinfo/devel>
> users mailing list
> users at rtems.org
