Resetting Eclipse C compiler choice
Adit Sahasrabudhe asahasra at fb.com
Wed May 13 20:11:03 UTC 2015
Hi Andrei,
Have you made sure that your RTEMS_MAKEFILE_PATH is set correctly in eclipse? Unless you set in elsewhere.
Adit
> On May 13, 2015, at 12:26 PM, Mr. Andrei Chichak <groups at chichak.ca> wrote:
> Hi there,
> I’m using Eclipse on a Mac (hey no snickers, it’s a BSD box) and it was working nicely, using arm-rtems4.11-gcc to do compiles, but it was getting a bit out of date.
> I grabbed the latest source builder distribution and reinstalled RTEMS tools from scratch.
> Suddenly Eclipse is using “gcc” to do compiles, which doesn’t exist.
> I tried munging the make files, but they get rebuilt every time you do a build.
> I tried munging the .cproject file, but it gets rebuilt every time you do a build.
> I tried munging the eclipse project preferences C/C++ Build/Settings/Tool Settings/RTEMS C Compiler/Command, but it gets reset on Apply.
> There are no automake files to deal with.
> Log off/on reboot doesn’t do it either.
> Arrg.
> What is the magic spell that I have to use to reset the compiler name prefix?
> Thanks a lot,
> Andrei from the Great White North
> users mailing list
> users at rtems.org
