Resetting Eclipse C compiler choice
Mohammed Saeed Khoory Mohammed.Khoory at mbrsc.ae
Thu May 14 04:24:22 UTC 2015
I also face this problem sometimes and I can't figure out what causes it. It particularly happens when I try to migrate my RTEMS installation directory to another computer by simple copying. I'm on Windows, MinGW and Eclipse.
I just end up rebuilding the tools as well as the RTEMS tree, maybe restart Eclipse, and it works once again.
> -----Original Message-----
> From: users [mailto:users-bounces at rtems.org] On Behalf Of Mr. Andrei
> Chichak
> Sent: Wednesday, May 13, 2015 11:26 PM
> To: RTEMS List
> Subject: Resetting Eclipse C compiler choice
> Hi there,
> I'm using Eclipse on a Mac (hey no snickers, it's a BSD box) and it was
> working nicely, using arm-rtems4.11-gcc to do compiles, but it was getting
> a bit out of date.
> I grabbed the latest source builder distribution and reinstalled RTEMS
> tools from scratch.
> Suddenly Eclipse is using "gcc" to do compiles, which doesn't exist.
> I tried munging the make files, but they get rebuilt every time you do a
> build.
> I tried munging the .cproject file, but it gets rebuilt every time you do
> a build.
> I tried munging the eclipse project preferences C/C++ Build/Settings/Tool
> Settings/RTEMS C Compiler/Command, but it gets reset on Apply.
> There are no automake files to deal with.
> Log off/on reboot doesn't do it either.
> Arrg.
> What is the magic spell that I have to use to reset the compiler name
> prefix?
> Thanks a lot,
> Andrei from the Great White North
> users mailing list
> users at rtems.org
