JFFS2 on RTEMS4.11 and GR712RC Eval Kit, zlib issue
Hoefle Marco
Marco.Hoefle at nanotronic.ch
Wed May 20 16:20:48 UTC 2015
Hello,
I am tying to include the JFFS2 example from embedded brains
https://devel.rtems.org/browser/rtems/cpukit/libfs/src/jffs2/include/rtems/jffs2.h#L46
I have set in rtems_config.h
* Configure file system and libblock.
#define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 32
#define CONFIGURE_FILESYSTEM_JFFS2
When building the application I get:
AR] libapp.a
sparc-rtems4.11-ar rcs libapp.a version.o jffs2_eval.o
make[1]: Leaving directory `/rtems4.11_test/src/app'
sparc-rtems4.11-gcc --pipe -B/rtems4.11_test/build/toolchain/sparc-rtems4.11/leon3/lib/ -specs bsp_specs -qrtems -Lapp -lapp -o build/cassis.elf app/init.o -Lapp -lapp
/rtems4.11_test/build/toolchain/sparc-rtems4.11/leon3/lib/librtemscpu.a(libjffs2_a-compr_zlib.o): In function `rtems_jffs2_compressor_zlib_compress':
/rtems4.11_test/rtems-source-builder/rtems/build/sparc-rtems4.11-kernel-4.11-1/sparc-rtems4.11-kernel-4.11-1-4.11/build/sparc-rtems4.11/c/leon3/cpukit/libfs/../../../../../../rtems-4.11/c/src/../../cpukit/libfs/src/jffs2/src/compr_zlib.c:61: undefined reference to `z_deflateInit_'
/rtems4.11_test/rtems-source-builder/rtems/build/sparc-rtems4.11-kernel-4.11-1/sparc-rtems4.11-kernel-4.11-1-4.11/build/sparc-rtems4.11/c/leon3/cpukit/libfs/../../../../../../rtems-4.11/c/src/../../cpukit/libfs/src/jffs2/src/compr_zlib.c:78: undefined reference to `z_deflate'
/rtems4.11_test/rtems-source-builder/rtems/build/sparc-rtems4.11-kernel-4.11-1/sparc-rtems4.11-kernel-4.11-1-4.11/build/sparc-rtems4.11/c/leon3/cpukit/libfs/../../../../../../rtems-4.11/c/src/../../cpukit/libfs/src/jffs2/src/compr_zlib.c:91: undefined reference to `z_deflate'
undefined reference to `z_inflateEnd'
collect2: error: ld returned 1 exit status
make: *** [build/cassis.elf] Error 1
zlib seems to be there:
/rtems4.11_test/build/toolchain/sparc-rtems4.11/leon3/lib$ ls -als
total 37372
4 drwxr-xr-x 3 hoefle domain users 4096 May 12 16:51 .
4 drwxr-xr-x 4 hoefle domain users 4096 May 12 16:51 ..
4 -rw-r--r-- 1 hoefle domain users 268 May 12 16:51 bsp_specs
28 -rwxr-xr-x 1 hoefle domain users 26629 May 12 16:51 dirutils.rel
4 drwxr-xr-x 14 hoefle domain users 4096 May 12 16:51 include
5112 -rw-r--r-- 1 hoefle domain users 5233410 May 12 16:51 librtemsbsp.a
31812 -rw-r--r-- 1 hoefle domain users 32573680 May 12 16:51 librtemscpu.a
376 -rw-r--r-- 1 hoefle domain users 382440 May 12 16:51 libz.a
4 -rw-r--r-- 1 hoefle domain users 454 May 12 16:51 linkcmds
8 -rw-r--r-- 1 hoefle domain users 4901 May 12 16:51 linkcmds.base
4 -rw-r--r-- 1 hoefle domain users 454 May 12 16:51 linkcmds.leon3
4 -rw-r--r-- 1 hoefle domain users 414 May 12 16:51 linkcmds.ngmp
8 -rw-r--r-- 1 hoefle domain users 6972 May 12 16:51 start.o
rtems was built using rsb
has anybody a hint how to proceed?
Marco
URL: <http://lists.rtems.org/pipermail/users/attachments/20150520/c5246a4e/attachment.html>
