Resetting Eclipse C compiler choice
Thu May 21 19:54:35 UTC 2015
On Thu, May 21, 2015 at 3:48 PM, Mr. Andrei Chichak <groups at chichak.ca> wrote:
> HAH, got it.
> Apparently if you update the tools it can break the BSPs. Then Eclipse will look for gcc instead of, say, arm-rtems4.11-gcc.
> So, the easiest thing is to expunge everything, source-builder the tools, git the source, and build the source and Eclipse will pick up the proper tools.
> Now, wouldn’t it be cool if source-builder could also download and build the RTEMS source? Or change the name to tool-builder?
It can, using --with-rtems flag.
> Andrei from The Great White North
> On 2015-May-13, at 10:12 PM, Mohammed Saeed Khoory <Mohammed.Khoory at mbrsc.ae> wrote:
>> I also face this problem sometimes and I can't figure out what causes it. It particularly happens when I try to migrate my RTEMS installation directory to another computer. I'm on Windows, MinGW and Eclipse.
>> I just end up rebuilding the tools as well as the RTEMS tree, maybe restart Eclipse, and it works once again.
>>> -----Original Message-----
>>> From: users [mailto:users-bounces at rtems.org] On Behalf Of Mr. Andrei
>>> Chichak
>>> Sent: Wednesday, May 13, 2015 11:26 PM
>>> To: RTEMS List
>>> Subject: Resetting Eclipse C compiler choice
>>> Hi there,
>>> I'm using Eclipse on a Mac (hey no snickers, it's a BSD box) and it was
>>> working nicely, using arm-rtems4.11-gcc to do compiles, but it was getting
>>> a bit out of date.
>>> I grabbed the latest source builder distribution and reinstalled RTEMS
>>> tools from scratch.
>>> Suddenly Eclipse is using "gcc" to do compiles, which doesn't exist.
>>> I tried munging the make files, but they get rebuilt every time you do a
>>> build.
>>> I tried munging the .cproject file, but it gets rebuilt every time you do
>>> a build.
>>> I tried munging the eclipse project preferences C/C++ Build/Settings/Tool
>>> Settings/RTEMS C Compiler/Command, but it gets reset on Apply.
>>> There are no automake files to deal with.
>>> Log off/on reboot doesn't do it either.
>>> Arrg.
>>> What is the magic spell that I have to use to reset the compiler name
>>> prefix?
>>> Thanks a lot,
>>> Andrei from the Great White North
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
