Pre-branching Testing Request
Fri May 22 12:36:27 UTC 2015
On May 21, 2015 4:19:25 PM CDT, Nick Withers <nick.withers at anu.edu.au> wrote:
>Hi all,
>On Wed, 2015-05-20 at 08:57 -0500, Joel Sherrill wrote:
>> Hi
>> Please test on your local hardware and report success or failures.
>> We are pushing clean up activities to be able to branch and make
>> a 4.11.0 as soon as possible.
>Any ideas on this post-timecounter one?
>____
>powerpc-rtems4.11-gcc --pipe -std=c99 -ggdb3 -Wall -Wextra -Wpedantic
>-Wconversion -Wwrite-strings -Wuninitialized -Wno-maybe-uninitialized
>-Werror -Wno-error=unused-function -Wno-error=unused-parameter
>-Wno-error=unused-variable -mcpu=powerpc -msoft-float -D__ppc_generic
>-I. -isystem
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include
>-DVERSION='"SVN 926:927M
>(svn+ssh://nsw103@nucserver1.anu.edu.au/home/system/svn-repos/daq/branches/dcp/src),
>built 2015-05-21 21:13:27 UTC"' -DVCS_VERSION='"SVN 926:927M
>(svn+ssh://nsw103@nucserver1.anu.edu.au/home/system/svn-repos/daq/branches/dcp/src)"'
>-DDEBUG=0 -DERR_WARN_HTTPD=0 -DSINGLES_SPECTRUM_LITTLE_ENDIAN -DNDEBUG
>-O2 -c -o collector.o collector.c
>In file included from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/percpu.h:29:0,
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/system.h:23,
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems.h:29,
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/endian.h:11,
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/sys/endian.h:33,
>                 from collector.c:30:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:
>In function '_Timestamp_Set_to_zero':
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:94:8:
>error: dereferencing pointer to incomplete type
>   _time->sec = 0;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:95:8:
>   _time->frac = 0;
Nick.. Since this is obviously happening with external source, can you put together a simple test case as Sebastian suggested?
>In function '_Timestamp_Less_than':
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:115:12:
>   if ( _lhs->sec < _rhs->sec )
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:115:24:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:118:12:
>   if ( _lhs->sec > _rhs->sec )
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:118:24:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:121:14:
>   return _lhs->frac < _rhs->frac;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:121:27:
>In function '_Timestamp_Greater_than':
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:141:12:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:141:24:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:144:12:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:144:24:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:147:14:
>   return _lhs->frac > _rhs->frac;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:147:27:
>In function '_Timestamp_Equal_to':
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:167:14:
>   return _lhs->sec == _rhs->sec && _lhs->frac == _rhs->frac;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:167:27:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:167:40:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:167:54:
>In function '_Timestamp_Add_to':
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:186:25:
>   time_t seconds = _time->sec;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:190:15:
>   return _time->sec - seconds;
>In function '_Timestamp_Subtract':
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:212:10:
>   _result->sec = _end->sec;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:212:22:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:213:10:
>   _result->frac = _end->frac;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:213:23:
>In function '_Timestamp_Get_seconds':
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/timestamp.h:265:15:
>   return _time->sec;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/system.h:23:0,
>from
>from
>from
>At top level:
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/percpu.h:316:21:
>error: field 'time_of_last_context_switch' has incomplete type
>   Timestamp_Control time_of_last_context_switch;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/tasks.h:43:0,
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/config.h:25,
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/config.h:57,
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems.h:33,
>from
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/score/thread.h:778:41:
>error: field 'cpu_time_used' has incomplete type
>   Thread_CPU_usage_t                    cpu_time_used;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems.h:55:0,
>from
>from
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:168:40:
>error: field 'min_cpu_time' has incomplete type
>   Thread_CPU_usage_t                   min_cpu_time;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:170:40:
>error: field 'max_cpu_time' has incomplete type
>   Thread_CPU_usage_t                   max_cpu_time;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:172:40:
>error: field 'total_cpu_time' has incomplete type
>   Thread_CPU_usage_t                   total_cpu_time;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:175:40:
>error: field 'min_wall_time' has incomplete type
>   Rate_monotonic_Period_time_t         min_wall_time;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:177:40:
>error: field 'max_wall_time' has incomplete type
>   Rate_monotonic_Period_time_t         max_wall_time;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:179:40:
>error: field 'total_wall_time' has incomplete type
>   Rate_monotonic_Period_time_t         total_wall_time;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:238:43:
>error: field 'cpu_usage_period_initiated' has incomplete type
>   Thread_CPU_usage_t                      cpu_usage_period_initiated;
>/home/nick/rtems/rtems-4.11/powerpc-rtems4.11/mvme3100/lib/include/rtems/rtems/ratemon.h:244:43:
>error: field 'time_period_initiated' has incomplete type
>   Rate_monotonic_Period_time_t            time_period_initiated;
>____
>I'm including sys/endian.h to get at htole16() and co., thusly in
>collector.c:
>____
>#define _POSIX_C_SOURCE 200809L
>#include <assert.h>
>#include <errno.h>
>#include <stdbool.h>
>#include <stdio.h>
>#include <stdint.h>
>#include <stdlib.h>
>#include <string.h>
>#include <sys/endian.h> // Non-standard hto16le() et al. functions
>____
>Cheers!
>Nick Withers
>Embedded Systems Programmer
>Department of Nuclear Physics, Research School of Physics and
>Engineering
>The Australian National University (CRICOS: 00120C)
--joel
