Dynamic loading
Till Straumann
strauman at slac.stanford.edu
Fri May 22 15:15:50 UTC 2015
Yes, you can. The easiest way is using NFS.
On 05/22/2015 07:12 AM, Robert Perez wrote:
> Hello everyone, I've been reading about RTEMS and I'm insterested in
> using it in a project, but for me the dynamic loading posibility is key.
> From other posts I know there exist the cexp shell that allow us to
> load binaries.
> It is not clear to me the following scenario though:
> One embedded board running RTEMS, connected via ethernet to a
> development machine.
> In the development machine I compile a .c program into an object file
> let's say a.out.
> Can I send the a.out file via ethernet and then load the binary with
> the cexp shell to run it ?
> Thanks, Robert.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150522/5960675c/attachment.html>
