Current master fails to build for RaspberryPi
Jan Sommer
soja-misc at aries.uberspace.de
Sun May 24 14:58:20 UTC 2015
Hi,
rebuilding rtems4.11 from current master for the raspberryPi failed today.
I went back through the history and the last commit which works for me is:
cc6938455edfa4dff79ce98320292e3a9c2e434b
I always used a fresh build folder and bootstrapped before the build to be
sure.
My configure is:
../rtems/configure --target=arm-rtems4.11\
--enable-rtemsbsp="raspberrypi" \
--enable-networking --enable-cxx --enable-posix \
--enable-tests=samples --prefix=$INSTALL_DIR
Can someone reproduce this?
Best regards,
Jan
The error log looks like this:
Making all in arm
make[7]: Entering directory '/home/jan/workspace/rtems-pi/taste-
way/build_rtems-4.11-pi/rtems-4.11-arm/build-rtems-4.11/arm-
rtems4.11/c/raspberrypi/cpukit/score/cpu/arm'
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I../../.. -
I../../../../cpukit/../../../raspberrypi/lib/include -mcpu=arm1176jzf-s -O2
-g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-
prototypes -Wnested-externs -MT libscorecpu_a-__aeabi_read_tp.o -MD -MP -MF
.deps/libscorecpu_a-__aeabi_read_tp.Tpo -c -o libscorecpu_a-__aeabi_read_tp.o
`test -f '__aeabi_read_tp.c' || echo
'../../../../../../../../rtems/c/src/../../cpukit/score/cpu/arm/'`__aeabi_read_tp.c
In file included from
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/percpu.h:29:0,
from
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/thread.h:31,
from
../../../../../../../../rtems/c/src/../../cpukit/score/cpu/arm/__aeabi_read_tp.c:19:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:
In function '_Timestamp_Set':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:78:3:
warning: implicit declaration of function 'timespec2bintime' [-Wimplicit-
function-declaration]
timespec2bintime( &_ts, _time );
warning: nested extern declaration of 'timespec2bintime' [-Wnested-externs]
In function '_Timestamp_Set_to_zero':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:94:8:
error: dereferencing pointer to incomplete type
_time->sec = 0;
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:95:8:
_time->frac = 0;
In function '_Timestamp_Less_than':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:115:12:
if ( _lhs->sec < _rhs->sec )
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:115:24:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:118:12:
if ( _lhs->sec > _rhs->sec )
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:118:24:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:121:14:
return _lhs->frac < _rhs->frac;
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:121:27:
In function '_Timestamp_Greater_than':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:141:12:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:141:24:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:144:12:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:144:24:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:147:14:
return _lhs->frac > _rhs->frac;
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:147:27:
In function '_Timestamp_Equal_to':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:167:14:
return _lhs->sec == _rhs->sec && _lhs->frac == _rhs->frac;
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:167:27:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:167:40:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:167:54:
In function '_Timestamp_Add_to':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:186:25:
time_t seconds = _time->sec;
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:188:3:
warning: implicit declaration of function 'bintime_add' [-Wimplicit-function-
declaration]
bintime_add( _time, _add );
warning: nested extern declaration of 'bintime_add' [-Wnested-externs]
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:190:15:
return _time->sec - seconds;
In function '_Timestamp_Subtract':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:212:10:
_result->sec = _end->sec;
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:212:22:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:213:10:
_result->frac = _end->frac;
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:213:23:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:215:3:
warning: implicit declaration of function 'bintime_sub' [-Wimplicit-function-
declaration]
bintime_sub( _result, _start );
warning: nested extern declaration of 'bintime_sub' [-Wnested-externs]
In function '_Timestamp_Divide':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:241:3:
warning: implicit declaration of function 'bintime2timespec' [-Wimplicit-
bintime2timespec( _lhs, &_ts_left );
warning: nested extern declaration of 'bintime2timespec' [-Wnested-externs]
In function '_Timestamp_Get_seconds':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:265:15:
return _time->sec;
In function '_Timestamp_To_timeval':
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/timestamp.h:335:3:
warning: implicit declaration of function 'bintime2timeval' [-Wimplicit-
bintime2timeval( _timestamp, _timeval );
warning: nested extern declaration of 'bintime2timeval' [-Wnested-externs]
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/thread.h:31:0,
from
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/percpu.h: At
top level:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/percpu.h:316:21:
error: field 'time_of_last_context_switch' has incomplete type
Timestamp_Control time_of_last_context_switch;
../../../../../../../../rtems/c/src/../../cpukit/score/cpu/arm/__aeabi_read_tp.c:19:0:
../../../../cpukit/../../../raspberrypi/lib/include/rtems/score/thread.h:778:41:
error: field 'cpu_time_used' has incomplete type
Thread_CPU_usage_t cpu_time_used;
Makefile:628: recipe for target 'libscorecpu_a-__aeabi_read_tp.o' failed
make[7]: *** [libscorecpu_a-__aeabi_read_tp.o] Error 1
make[7]: Leaving directory '/home/jan/workspace/rtems-pi/taste-
Makefile:366: recipe for target 'all-recursive' failed
make[6]: *** [all-recursive] Error 1
make[6]: Leaving directory '/home/jan/workspace/rtems-pi/taste-
rtems4.11/c/raspberrypi/cpukit/score/cpu'
Makefile:5038: recipe for target 'all-recursive' failed
make[5]: *** [all-recursive] Error 1
make[5]: Leaving directory '/home/jan/workspace/rtems-pi/taste-
rtems4.11/c/raspberrypi/cpukit/score'
Makefile:1030: recipe for target 'all-recursive' failed
make[4]: *** [all-recursive] Error 1
make[4]: Leaving directory '/home/jan/workspace/rtems-pi/taste-
rtems4.11/c/raspberrypi/cpukit'
Makefile:715: recipe for target 'all' failed
make[3]: *** [all] Error 2
make[3]: Leaving directory '/home/jan/workspace/rtems-pi/taste-
Makefile:487: recipe for target 'all-recursive' failed
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory '/home/jan/workspace/rtems-pi/taste-
rtems4.11/c/raspberrypi'
Makefile:348: recipe for target 'all-recursive' failed
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory '/home/jan/workspace/rtems-pi/taste-
way/build_rtems-4.11-pi/rtems-4.11-arm/build-rtems-4.11/arm-rtems4.11/c'
Makefile:473: recipe for target 'all-recursive' failed
make: *** [all-recursive] Error 1
