RTEMS ARM build fails, timespec2bintime
Robert Perez
robertperez67 at hotmail.com
Mon May 25 22:12:09 UTC 2015
Thanks Joel, I trust you :-)
This could be a simple question but, how to I update the toolset ? Since I just cloned from Ben Grass git yesterday with:
git clone -b beagle https://github.com/bengras/rtems-source-builder.git
I'm looking for it, but a little help is very welcomed.Thanks !> Subject: Re: RTEMS ARM build fails, timespec2bintime
> From: joel.sherrill at oarcorp.com
> Date: Sun, 24 May 2015 21:51:37 -0500
> To: robertperez67 at hotmail.com; users at rtems.org
> On May 24, 2015 9:13:24 PM CDT, Robert Perez <robertperez67 at hotmail.com> wrote:
> >Hi everyone, I'm trying to build RTEMS for the beaglebone using this
> >tutorial
> >http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
> >but when executing the make command some errors are appearing regarding
> >the timespec2bintime function, seems not to be declared, also some
> >related structs are not recognized (please see the attachment)
> >I've seen in https://sourceware.org/ml/newlib/2015/msg00186.html and
> >https://devel.rtems.org/ticket/2271 changes that could be related to
> >this error as I understand, but I'm new with RTEMS and I'm stuck at
> >this now.
> >Also tried to build using the raspberry pi with this other tutorial
> >http://alanstechnotes.blogspot.com/2013/03/compiling-and-installing-rtems-for.html
> >and the same happens.
> >Any helps is appreciated.
> This stuff was added to newlib recently. You need a new toolset. Update the RSB, build tools and you will be OK.
> I promise I have built every BSP in the last week.
> >Regards, Robert.
> --joel
URL: <http://lists.rtems.org/pipermail/users/attachments/20150525/10c36fed/attachment.html>
