RTEMS ARM build fails, timespec2bintime
Mon May 25 23:20:10 UTC 2015
On May 25, 2015 5:12:09 PM CDT, Robert Perez <robertperez67 at hotmail.com> wrote:
>Thanks Joel, I trust you :-)
>This could be a simple question but, how to I update the toolset ?
>Since I just cloned from Ben Grass git yesterday with:
Ahh.. You need his repo to get the qemu that does BB right. But he apparently hasn't rebased against the master at git.rtems.org.
>git clone -b beagle https://github.com/bengras/rtems-source-builder.git
>I'm looking for it, but a little help is very welcomed.
>Thanks !
>> Subject: Re: RTEMS ARM build fails, timespec2bintime
>> From: joel.sherrill at oarcorp.com
>> Date: Sun, 24 May 2015 21:51:37 -0500
>> To: robertperez67 at hotmail.com; users at rtems.org
>> On May 24, 2015 9:13:24 PM CDT, Robert Perez
>> >Hi everyone, I'm trying to build RTEMS for the beaglebone using this
>> >tutorial
>>http://www.shrike-systems.com/beagleboard-xm-beaglebone-black-and-everything-else-rtems-on-the-beagles.html
>> >but when executing the make command some errors are appearing
>regarding
>> >the timespec2bintime function, seems not to be declared, also some
>> >related structs are not recognized (please see the attachment)
>> >I've seen in https://sourceware.org/ml/newlib/2015/msg00186.html and
>> >https://devel.rtems.org/ticket/2271 changes that could be related to
>> >this error as I understand, but I'm new with RTEMS and I'm stuck at
>> >this now.
>> >Also tried to build using the raspberry pi with this other tutorial
>>http://alanstechnotes.blogspot.com/2013/03/compiling-and-installing-rtems-for.html
>> >and the same happens.
>> >Any helps is appreciated.
>> This stuff was added to newlib recently. You need a new toolset.
>Update the RSB, build tools and you will be OK.
>> I promise I have built every BSP in the last week.
>> >Regards, Robert.
>> --joel
--joel
