RSB: Continue from where interrupted
Tue May 26 15:03:45 UTC 2015
Saeed,
That is a normal complaint. It needs to go in our FAQ or RSB started
guide. RSB aims to provide a single integrated build solution across
multiple platforms, and it is diffiuclt to ensure that every step
along the way to a failure is good to reuse. Therefore the RSB design
chooses instead to restart/rebuild everything.
Gedare
On Tue, May 26, 2015 at 5:44 AM, Saeed Ehteshamifar
<salpha.2004 at gmail.com> wrote:
> Hi,
> I'm using RTEMS Source Builder to build the tools for RTEMS 4.11/Kubuntu.
> However the build failed when building gdb. I tried to resolve the error and
> continue the build process but RSB tries to build all the tools again (just
> skipping download phase).
> I'm wondering if "make" is being used under the hood, why the build process
> starts over and is there any way to avoid this and continue build from where
> interrupted?
> I'm invoking "sb-set-builder" to build the tools.
> Kind Regards,
> SAeeD
> users mailing list
> users at rtems.org
