examples-v2/led for stm32f4 BSP
Wed May 27 20:15:15 UTC 2015
Hi Steve,
Could you send this as a patch to devel at rtems.org mailing list? See
https://devel.rtems.org/wiki/Developer/Contributing
Also, documentation improvements are always welcome, and usually
easiest to do while spending time getting up-and-running.
Thanks, and glad you didn't have too much difficulty!
Gedare
On Wed, May 27, 2015 at 2:42 PM, Steve B <sbattazzo at gmail.com> wrote:
> Hello all,
> In an effort to get myself acquainted with an easily accessible BSP I
> decided I would like to make one of the the examples-v2/led examples work
> with STM32F4.
> Without detailed documentation it wasn't painfully obvious what was the
> minimum I would need to modify, but in the end it was pretty manageable to
> figure it out from the code, and I only had to write a few lines of code to
> led.h.
> Will go ahead and attach in case this is something somebody might find to be
> a useful hint to save a couple hours of tracing the BSP code around.
> I only tried this with the "timer" example, but I imagine the others should
> work just fine too?
> Steve
> users mailing list
> users at rtems.org
