Compilation error of rtems for sparc-leon2 with multilib enabled
    Jan Sommer
    soja-misc at aries.uberspace.de
    Sat May  2 16:22:50 UTC 2015
Am Samstag, 2. Mai 2015, 11:09:00 schrieb Joel Sherrill:
> On May 2, 2015 11:00:55 AM CDT, Jan Sommer <soja-misc at aries.uberspace.de>
wrote:
> >It works if I don't use --enable-multilib
> That's the issue. A normal BSP build doesn't turn that on. It was added long
> ago as a testing way to ensure the cpukit could be successfully compiled
> for all CPU model variants gcc knows even if we don't have a BSP that
> really uses it or if the odd combination even exists in silicon. Disable
> that and the leon2 will build.
Ok, I didn't know that. It's a bit confusing to me. When building gcc you
usually want to enable-multilib and here you shouln't?
> Out of curiosity, what combination isn't building?
How would I find out? Tried to find something in the build log but wasn't sure
what I was looking for.
Anyways, thank you very much for your help.
