Embedded board with good support out of the box?
Steve B sbattazzo at gmail.com
Thu May 28 22:41:55 UTC 2015
On Thu, May 28, 2015 at 4:49 AM, Ben Gras <beng at shrike-systems.com> wrote:
> On Fri, May 22, 2015 at 1:39 AM, Steve B <sbattazzo at gmail.com> wrote:
> > I need CAN bus, a couple of UARTs (one of which may need interrupts),
> some
> > sort of ADC (whether it is the built in one or external), file logging,
> and
> > some GPIO. No need for Ethernet unless it really proves useful in
> uploading
> > software remotely or spitting out diagnostic data faster than a UART can
> > handle.
> > BBB seems to only have polled console and I2C in the bsp currently.
> Not to nitpick, but non-polled console on the BBB works. The
> peripheral support is otherwise thin yes.
Thanks Ben, I did not know that! Do multiple UARTs work, or only the "main"
one?
I can actually start implementing parts of my application right away if
there is more than one UART.
If not, I can help add them!
Steve
URL: <http://lists.rtems.org/pipermail/users/attachments/20150528/604ab426/attachment-0002.html>
