Possible bug and lacking feature in BBB bsp, GPIO API hooks
André Marques
andre.lousa.marques at gmail.com
Sat Nov 7 09:26:46 UTC 2015
Hello
Às 17:31 de 02-11-2015, Steve B escreveu:
> I just looked at some sample code on Ketul's github, and the source
> code of the API itself, rather than any actual documentation.
Documentation on the GPIO API can be found in
https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card#RTEMSGPIOAPI
> I have already made calls to rtems_gpio_initialize() and
> rtems_gpio_request_pin() as Ketul suggested.
> I am about to go on travel but I will attach my code once tonight I
> get settled in, and maybe one of you can run it and see if you agree
> with me on the symptom.
> Steve
> On Sat, Oct 31, 2015 at 6:45 AM, Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> This problem indicates a lack of clear documentation. Steve, where did
> you look for guidance on using the API?
> On Sat, Oct 31, 2015 at 5:11 AM, Ketul Shah
> <ketulshah1993 at gmail.com <mailto:ketulshah1993 at gmail.com>> wrote:
> > Hi Steve,
> > I suggest you to kindly configure GPIO API by using following
> functions in
> > your code,
> > rtems_gpio_initialize();
> > rtems_gpio_request_pin(.....);
> > After using it should work properly. Me and Ben had tested on
> our BBBs.
> > For example code you can have a loot at link.
> > Hope this helps.
> > Thanks,
> > Ketul
> > On 31 October 2015 at 05:11, Steve B <sbattazzo at gmail.com
> <mailto:sbattazzo at gmail.com>> wrote:
> >> Hi again guys,
> >> I've noticed an unexpected (to me) behavior in the GPIO API for
> Beaglebone
> >> Black.
> >> I borrowed a periodic task from the clock test source, and set
> it up to
> >> toggle the GPIOs once every couple seconds.. here's what I have:
> >> rtems_task Test_task(
> >> rtems_task_argument task_index
> >> int task_count = 0;
> >> rtems_time_of_day time;
> >> rtems_interval ticks;
> >> ticks = task_index * 2 * rtems_clock_get_ticks_per_second();
> >> for ( ; ; ) {
> >> task_count++;
> >> (void) rtems_clock_get_tod( &time );
> >> if ( time.second >= 35 ) {
> >> puts( "*** END OF CLOCK TICK TEST ***" );
> >> //exit( 0 );
> >> while(1);
> >> put_name( Task_name[ task_index ], FALSE );
> >> print_time( " - rtems_clock_get_tod - ", &time, "\n" );
> >> //Toggle GPIO
> >> if(task_count & 1) {
> >> rtems_gpio_set(LED1);
> >> rtems_gpio_set(LED2);
> >> else rtems_gpio_clear(LED1);
> >> (void) rtems_task_wake_after( ticks );
> >> Notice I've defined that if the least significant bit of my
> variable
> >> task_count is 1, then I set both LED1 and LED2. If that LSB is
> zero, I just
> >> call to clear LED1.
> >> When I actually run this, both LED1 and LED2 are being cleared!
> Same is
> >> true with the 3rd and 4th user LEDs as well, if I happen to set
> all four of
> >> them. So I think somehow rtems_gpio_bsp_clear() is clearing the
> entire bank,
> >> not just the single pin specified in the argument. Can somebody
> confirm this
> >> behavior?
> >> I will dig around and see if I can figure out why it's
> happening and
> >> generate a patch if I find it.
> >> Also, I was hoping to be able to toggle a GPIO output by
> checking its
> >> current state and using that to decide whether to set or clear,
> but I don't
> >> see anything in the API that would allow me to check the state
> of an output.
> >> Is this a known/intended limitation?
> >> Cheers,
> >> Steve
> >> _______________________________________________
> >> users mailing list
> >> users at rtems.org <mailto:users at rtems.org>
> >> http://lists.rtems.org/mailman/listinfo/users
> > users mailing list
> users mailing list
> users at rtems.org
--André Marques
URL: <http://lists.rtems.org/pipermail/users/attachments/20151107/9679d29b/attachment.html>
