thread allocation blocked by stack size
Martin Werner martin.werner at aacmicrotec.com
Wed Nov 11 11:08:08 UTC 2015
On Wed, 2015-11-04 at 08:00 +0100, Sebastian Huber wrote:
> On 03/11/15 13:40, Martin Werner wrote:
> > On Tue, 2015-11-03 at 09:09 +0100, Sebastian Huber wrote:
> >> >Use only:
> >> >#define CONFIGURE_UNIFIED_WORK_AREAS
> >> >#define CONFIGURE_UNLIMITED_OBJECTS
> > I have tried doing this, with no visible change in behaviour.
> It may help if you send us the actual source code of your configuration
> and a simple test case that reproduces the problem.
I have managed to solve/work around the issues by switching over to
using only the posix api, and I'm afraid I won't test/poke into the
mixed API case further at the moment.
Thanks for help along the way.
Martin Erik Werner <martin.werner at aacmicrotec.com>
ÅAC Microtec AB
