c++ std::thread
Thu Nov 12 06:08:36 UTC 2015
On 12/11/2015 3:35 PM, Webb, Jeffrey A. wrote:
> I just tried to start over from scratch like this:
Thank you for testing this.
> $ git clone git://git.rtems.org/rtems-source-builder.git
> $ cd rtems-source-builder
> $ source-builder/sb-check
> cd rtems
> $ ../source-builder/sb-set-builder \
>          --log=build-log.txt \
>          --prefix=$HOME/development/rtems/compiler/4.12 \
>           4.12/rtems-sparc
> I first had trouble with the www.mpfr.org site:
The site appears to be down.
> download: http://www.mpfr.org/mpfr-2.4.2/mpfr-2.4.2.tar.bz2 -> sources/mpfr-2.4.2.tar.bz2
> download: http://www.mpfr.org/mpfr-2.4.2/mpfr-2.4.2.tar.bz2: error: <urlopen error [Errno 110] Connection timed out>
> error: downloading http://www.mpfr.org/mpfr-2.4.2/mpfr-2.4.2.tar.bz2: all paths have failed, giving up
> I solved this error by downloading the package manually from here:
> http://ftp.gnu.org/gnu/mpfr/
> and placing it in the sources directory.
> I then had this problem:
> download: https://git.rtems.org/rtems-tools/plain/tools/4.12/gdb/gdb-sim-arange-inline.diff -> patches/gdb-sim-arange-inline.diff
> download: https://git.rtems.org/rtems-tools/plain/tools/4.12/gdb/gdb-sim-arange-inline.diff: error: HTTP Error 404: Not found
> error: downloading https://git.rtems.org/rtems-tools/plain/tools/4.12/gdb/gdb-sim-arange-inline.diff: all paths have failed, giving up
> ... but it seems that the 4.12 directory does not exist yet.  I see that the missing file is in the 4.11 directory, so I tried to download it and place it in the sources directory as well.  That failed with the same error as before.  Perhaps that is not the proper location for the diff file.  I am wondering if there is something you forgot to update for 4.12, or perhaps I did something wrong, since it's been a couple of months since I last went through this process.
Ah yes. I will sort this out now.
